HRBL Posted September 13, 2019 Share Posted September 13, 2019 Had the 350 for a few months now with no issues (other than the gearbox grinding into second gear, but that's a common thing it seems!). Then randomly yesterday I get a check engine light. Did the pedal dance and it threw up P1166 and P1167. Today I tried it again, and it's just P1166 now. Either way they seem to refer to the exact same issue (?) - Heated O2 Sensor 2. Is this as simple as changing out the sensor for a new one? As far as I can tell the car has a stock exhaust, though it does seem a little louder than completely stock, it looks like nothings changed and it's definitely not been straight piped. From what I've read this code gets thrown up with modifications, but surely it'd have come up earlier if this was the case - I've done ~1500 miles now with no engine management light at all. Thanks for any help Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted September 13, 2019 Share Posted September 13, 2019 My O2 sensors throw a wobbly every year or so. Standard car. I reset it. Everything is fine. Maybe a couple years later and it'll happen again. As long as it's not constantly coming back, the sensors may be fine. Just a hissy fit that some sensors throw up these cars. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 13, 2019 Share Posted September 13, 2019 You could try a reset and if the CEL reappears you could fit an O2 Lamda simulator. If the issue is still there then test the sensor and replace if faulty. If your car has had an uprev you can turn the rear sensors off so that they do not throw a CEL. Quote Link to comment Share on other sites More sharing options...
HRBL Posted September 13, 2019 Author Share Posted September 13, 2019 Thanks all - I'll reset the code and see if it returns. I take it that it's reasonably safe to assume this isn't a major deal then? Quote Link to comment Share on other sites More sharing options...
davey_83 Posted September 14, 2019 Share Posted September 14, 2019 If you've now down that mileage with no cel light on, I wouldn't worry too much Quote Link to comment Share on other sites More sharing options...
