jamesd Posted September 10, 2019 Share Posted September 10, 2019 Hi all My 350 had a front smash and the aircom rad is mangled.can i just take it out and leave the rest of the system? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 11, 2019 Share Posted September 11, 2019 If you want the air con to work you will require to fit a replacement aircon rad. If you run the 350 without aircon, I think that you will definitely regret it. But the answer to your question is yes, but remove the belt as well. Preowned aircon rads are in stock and good to go same/next day if required. Quote Link to comment Share on other sites More sharing options...
jamesd Posted September 11, 2019 Author Share Posted September 11, 2019 Cheers Alex. She's gonna be a track car so won't be needing the aircon really. Was a Cat B write off so only usable on the track. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 11, 2019 Share Posted September 11, 2019 In that case, pull off the compressor as well and save a few kg. Quote Link to comment Share on other sites More sharing options...
