alexbuilds Posted September 7, 2019 Share Posted September 7, 2019 So I am going to have my clutch done soon and have been quoted £480 but said if the flywheel needed doing then another £260 I ask if that sounds about right cost ? Also flywheel should I get it done anyway should i get a different type (lighter one) What advantages recommended makes of clutch or flywheel cheers Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted September 7, 2019 Share Posted September 7, 2019 (edited) It’s always advised to replace the flywheel when replacing the clutch as you’ll be only paying for the flywheel it self basically as part of the clutch change. If your sticking with the OEM set up it’s best to use fhe OEM Exedy clutch and LUK dual mass flywheel. For After market the extreme clutch kit is a good step up. Also if your Zeds a HR you’ll definitely want to be getting the slave cylinder replaced too. https://www.cougarstore.co.uk/nissan-350z-clutches-12-c.asp Edited September 7, 2019 by SHEZZA Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted September 7, 2019 Share Posted September 7, 2019 As recommended above^ Gotta love the OC for good friendly advice Quote Link to comment Share on other sites More sharing options...
alexbuilds Posted September 11, 2019 Author Share Posted September 11, 2019 Thanks for the advice it's really helpful to me Quote Link to comment Share on other sites More sharing options...
