Cn12345 Posted September 1, 2019 Share Posted September 1, 2019 Hi guys, we recently had the banana arm replaced and was just wondering if the subframe brace would of had to of come off completely in order to replace it? Thanks Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted September 1, 2019 Share Posted September 1, 2019 Yes it would of had to come off to replace the banana arms. Quote Link to comment Share on other sites More sharing options...
Cn12345 Posted September 1, 2019 Author Share Posted September 1, 2019 Thank you buddy. Looking at replacing the subframe brace as it looks a little rusty and didn’t really want to do it if the bolts could of potentially snapped when trying to unbolt them. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 1, 2019 Share Posted September 1, 2019 I have removed around 50 of these and have never snapped a subframe bolt. Quote Link to comment Share on other sites More sharing options...
Cn12345 Posted September 1, 2019 Author Share Posted September 1, 2019 38 minutes ago, ZMANALEX said: I have removed around 50 of these and have never snapped a subframe bolt. I think I just have a bit or paranoia about snapping one. Have you had any issues with removing any bolts on the engine cradle or W brace at all? Looking to get some por15 on them areas properly but as above worry about snapping bolts. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 1, 2019 Share Posted September 1, 2019 No issues with the engine cross member fixings, Periodically the 8mm bolts snap on the W bracing but these are easily drilled and retapped as they are into the bracing end brackets. Quote Link to comment Share on other sites More sharing options...
Cn12345 Posted September 1, 2019 Author Share Posted September 1, 2019 That’s good to know, thank you Quote Link to comment Share on other sites More sharing options...
MDMetal Posted September 2, 2019 Share Posted September 2, 2019 16 hours ago, Cn12345 said: That’s good to know, thank you I've swapped my arms without having to drop the brace, you can leave it with the opposite side loose while replacing an arm and then swap, this saves you having it on the floor and lifting it up again. Bolts are nice and thick and while the nuts might have seized some PB blaster and a long breaker bar gets them off without too much hassle. Quote Link to comment Share on other sites More sharing options...
Cn12345 Posted September 2, 2019 Author Share Posted September 2, 2019 6 hours ago, MDMetal said: I've swapped my arms without having to drop the brace, you can leave it with the opposite side loose while replacing an arm and then swap, this saves you having it on the floor and lifting it up again. Bolts are nice and thick and while the nuts might have seized some PB blaster and a long breaker bar gets them off without too much hassle. Noted. thanks for everyone’s help, saves me taking it to the garage if I can do it myself Quote Link to comment Share on other sites More sharing options...
