michaelgordon Posted August 31, 2019 Share Posted August 31, 2019 I looked round and on the american site for a guide to put an earthing kit into my Hr and while there were a few for DE they were not suitable so i decided to just do it. I used the Stillen install instructions as a base line but as they are american, the battery is on the wrong side so guessed really. Not completely sure I've done it right but car starts so i don't think I've messed any thing up. If anyone has any suggestions or can point out where i may have gone wrong please comment and let me know. I did clean the paint from any parts of the chassis that made contact. Cant say ive noticed a different on the volt meter either at ignition or with engine running. Not driven it yet so cant comment on idle, smoothness or increased electrical efficiency, to bright for headlights yet which has been reported as improving from other threads and topics i read. First pic, overall finished showing most the connection. First - There is a threaded hole just behind the washer fluid cap. This was a bit of a pain due to location but it eventually went in. From here this cable routes to the engine block. Second - The first cable from threaded hole into engine block & a second cable from engine block to lower earth point on block. Third - You can see the cable going to the lower earthing point from the block above. The third cable goes from the upper earthing point, not the top one but the one in the middle of this pic to the bottom threaded hole next to the intake. Fourth - The cable in the bottom threaded hole from the middle earthing point from previous picture. Also from the previous pic the Top earth point cable goes to a bolt under the air con tap, this can be seen better in the next pic. Fifth - Pic showing cable from top earth point to bolt by air con cap. There is then a cable from this to the top threaded hole in previous pic. Sixth - I put two extra from the current battery earth point to battery, there is also a cable running from the chassis connector to the top threaded hole in pic 5, this ran under the wiring loom foam block. Quote Link to comment Share on other sites More sharing options...
Ben.B.HR Posted April 2, 2020 Share Posted April 2, 2020 Have you noticed any gains or better throttle response after doing this? Been considering doing this with mine as from time to time I feel a acceleration stutter. Quote Link to comment Share on other sites More sharing options...
coldel Posted April 3, 2020 Share Posted April 3, 2020 There is I believe some data in Horsham developments website about this...I got one years ago and must noticed nothing (many people call it snake oil) but it does look cool if you get a nice colour! if you have acceleration stutter would recommend posting up details for forum members to comment on Quote Link to comment Share on other sites More sharing options...
Ben.B.HR Posted April 3, 2020 Share Posted April 3, 2020 10 minutes ago, coldel said: There is I believe some data in Horsham developments website about this...I got one years ago and must noticed nothing (many people call it snake oil) but it does look cool if you get a nice colour! if you have acceleration stutter would recommend posting up details for forum members to comment on Yeah I might have too. Although I read on the american forums that the stutter could be a grounding issue. Will try that first then come to the forums after if no good. Quote Link to comment Share on other sites More sharing options...
coldel Posted April 3, 2020 Share Posted April 3, 2020 Check and clean all your current grounds Quote Link to comment Share on other sites More sharing options...
Payco Posted April 3, 2020 Share Posted April 3, 2020 1 hour ago, coldel said: Check nd clean all your Had them on my 350z DE 6 years ago. Looked nice but didn't make any difference. More bling than zing. Quote Link to comment Share on other sites More sharing options...
michaelgordon Posted April 3, 2020 Author Share Posted April 3, 2020 Nothing too noticeable really. I did this quite soon after getting it so wasn't really used the the feel. The way I looked at it was that it can't really do any harm. I only did it as in my last car there really was an improvement everything just felt smoother. Quote Link to comment Share on other sites More sharing options...
