Crank pulley damage
evilscorp
What is people's opinion of this damage on my sr20det crank pulley.
The damage was my own fault when trying to remove the thing and not winding out the bolt enough when using the puller and it broke the flange at the three points the puller was attached.
The pulley in question is for the alternator and water pump its about 3/4" thick belt width, the only other belt is for the power steering which is in the next grooves on the smaller diameter section.
If it was for my 350z I would replace it but I am not so sure how much money I want to spend on this engine when I will probably end up swapping in a VQ35DE in a few/many years time.
68635927_10162260249755441_8042553718933
68836005_10162260249505441_3995935811538
69083525_10162260249595441_5378569076421
The thing is very rusty and have washed and cleaned it up, I may spray paint if I reuse it as the rubber still isn't ripped but it is showing wear and marks.
