zimon14 Posted August 20, 2019 Share Posted August 20, 2019 Hey all, Finally trying to get my 07 plate HR back on the road after a bit of time . And have a slight issue the left hand window won't move from either the passenger or drivers switch and the mirror won't fold in, however the window will raise and lower when opening the door and the mirror lens moves fine. Any ideas I'm thinking the issues may be connected? thanks in advance for any help SI Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 20, 2019 Share Posted August 20, 2019 First thing to do is check the contacts on the multi-plug at the door jamb. Quote Link to comment Share on other sites More sharing options...
Fire_eyes Posted August 24, 2019 Share Posted August 24, 2019 Mine has also started doing this so would also be interested if anyone has fixed this already. Thanks Stuart Quote Link to comment Share on other sites More sharing options...
davey_83 Posted August 24, 2019 Share Posted August 24, 2019 On 20/08/2019 at 15:44, zimon14 said: Hey all, Finally trying to get my 07 plate HR back on the road after a bit of time . And have a slight issue the left hand window won't move from either the passenger or drivers switch and the mirror won't fold in, however the window will raise and lower when opening the door and the mirror lens moves fine. Any ideas I'm thinking the issues may be connected? thanks in advance for any help SI Quote Link to comment Share on other sites More sharing options...
Exotic Posted August 27, 2019 Share Posted August 27, 2019 I've got a slightly different issue with my passenger side window. Basically it will sometimes not respond (either after initially putting it up or down) but after a few tries it eventually does play ball. I'd rather not run into a situation in the future where I leave the car parked with that window down because it's failed completely. Anyone else had this? Quote Link to comment Share on other sites More sharing options...
