Coolant change... Dont need over 9 litres!
letsgotopless
I recently did a differential and gearbox oil change, no problem :thumbs:.
The coolant swap came next and followed several youtube guides to make sure i was not missing something even though its a simple and straight forward operation.
I warmed the car up, put heater setting on hot, ramped the front up a little and then released the fluid by removing the plastic plug under the radiator and opened the pressure cap. After 20 mins i opened the bleed valve on the small top hose and left it all for half hour to fully drain. I thought about turning over the engine briefly to get the water pump to send some more out but decided against that and anyway, no one had suggested it.  I opened my first 5 litre bottle of nissan premixed coolant and slowly filled up and continued the process over a few hours according to the guides. All easy but after fully filling and bleeding the system with no air left therein I found that no more than the 5 litres was needed.
Have any of you guys found this also. Now I have a spare unopened 5 litre of coolant.
  • 10 months later...
  • 2 months later...
