DanFino Posted August 12, 2019 Share Posted August 12, 2019 Hello. I've had my Fairlady off the road for a little while to do some jobs. Started it today, tried to clear the screen and nothing from the screenwash. It's got liquid in, and it worked the last time I tried it. The front at least did the rear never has. Pulled the fuse, that was fine. Got the wife to try it while I was outside the car. No noise from either motor. So while she worked the switches I put a circuit tester across the fuse gap. 12v when either is activated. My guess is the motors have both gone. I just wanted to check out night be something else I haven't thought of. Any ideas? Quote Link to comment Share on other sites More sharing options...
Umster Posted August 12, 2019 Share Posted August 12, 2019 Poke a pin into the washers? Might just need clearing out of dirt/dried gunk. Not sure if it's similar to the 370Z where you can see the liquid flow in a tube under the hood. See if anything is being pushed around etc. 1 Quote Link to comment Share on other sites More sharing options...
G1en Posted August 12, 2019 Share Posted August 12, 2019 Probably both motors need replacing as you say. I had to do same around 2 years back. If you cant hear any noise they have packed in. Cost me around £45 i think for both. 1 Quote Link to comment Share on other sites More sharing options...
DanFino Posted August 12, 2019 Author Share Posted August 12, 2019 Yeah I have ordered some aftermarket ones from eBay. Hopefully we're right :-) Quote Link to comment Share on other sites More sharing options...
DanFino Posted August 20, 2019 Author Share Posted August 20, 2019 Ok update to this in case anyone is interested. Both motors were really old and looked crudded up and knackered. Found a new front motor on eBay for £7.99 but a rear one was £30.00. so I just bought 2 front ones.. Sure enough they are the same motor but with different connectors. As the connectors on mine looked knackered. So I cut them off and soldered in some insulated Spade connectors on both. On each motor the orange wire is the positive. Then I wrapped them in self amalgamating tape. Refilled, tested, worked. Quite happy with a £16 repair really. 1 Quote Link to comment Share on other sites More sharing options...
