Gr00vy Posted August 1, 2019 Share Posted August 1, 2019 Hi All, Anyone know which sensor fault code p0134 ho2s1 (b1) relates to? I'm assuming bank 1, drivers side and then is it the O2 sensor on the CAT or the one on the Manifold that seems like a bugger to get to? Also if it's the one on the manifold is it a massive job to do? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 1, 2019 Share Posted August 1, 2019 P0134 is Bank 1 Sensor 1 So front sensor in the manifold, which is quite easy to remove providing it is not seized and you have the correct 02 sensor socket. Quote Link to comment Share on other sites More sharing options...
Gr00vy Posted August 2, 2019 Author Share Posted August 2, 2019 @ZMANALEX, Thanks much appreciated. Would the below tool be okay or any recommendations? https://www.amazon.co.uk/Laser-4257-Lambda-Socket-Wrench/dp/B00307POT2/ref=sr_1_3?keywords=o2+sensor+tool&qid=1564746352&s=gateway&sr=8-3 Quote Link to comment Share on other sites More sharing options...
