RoadHog Posted July 28, 2019 Share Posted July 28, 2019 Hi all I had an issue New Year’s Eve where my flexi pipe split causing back pressure issues so had a custom exhaust place weld some plates on (had the other side done too as it’s been on there same amount of time in case it cracked too) since then, when the car comes down the revs, no matter which gear, always exactly 2000rpm it makes a rattle/crunch noise from under the footwells. Garage are adamant it’s heat shields as they were loose and I noticed after testing at 200rpm you could actually sometimes feel something hit the under side of the car in the foot well so I thought they’re probably right, Iv left it since then and I believe the driver side shield has fallen off since so doesn’t sound as bad but the passenger side one sounds horrendous now at 2000rpm and isle (but nice when accelerating lol) almost sounds like they’re blowing now it’s a lot louder so I’m wondering if they’ve had it and thinking about replacing them looking for advice on either a repair option or replacement option, maybe some sport ones? I already have the optional extra nismo back box so it sounds quite nice once accelerating so maybe some sports cats might finish it off nicely Don’t really want to spend any more than 300-400 on a bit of a budget I’m afraid but open to sound advice and if worth pushing the pennies then maybe thanks in advance Martyn Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 28, 2019 Share Posted July 28, 2019 Just remove the heat shields, simples, and you will have plenty change from your 300-400 budget to have a week in Spain. Quote Link to comment Share on other sites More sharing options...
RoadHog Posted July 28, 2019 Author Share Posted July 28, 2019 Guessing not as dangerous as the garage made out then? is it easy to do? Sorry I haven’t managed to get under the car yet to look Quote Link to comment Share on other sites More sharing options...
RoadHog Posted July 28, 2019 Author Share Posted July 28, 2019 12 minutes ago, ZMANALEX said: Just remove the heat shields, simples, and you will have plenty change from your 300-400 budget to have a week in Spain. Guessing not as dangerous as the garage made out then? is it easy to do? Sorry I haven’t managed to get under the car yet to look Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 28, 2019 Share Posted July 28, 2019 By what you say they are loose and rattling, so probably well corroded so should come off very easily. 1 Quote Link to comment Share on other sites More sharing options...
Jack94 Posted July 29, 2019 Share Posted July 29, 2019 Gotta be worth a go grinding the heatshields off to see if that cures your issue. If it doesn't then sounds like the perfect opportunity to upgrade to some high flow cats I've got torqen ones (£419) and can't fault them. 1 Quote Link to comment Share on other sites More sharing options...
RoadHog Posted July 29, 2019 Author Share Posted July 29, 2019 10 hours ago, ZMANALEX said: By what you say they are loose and rattling, so probably well corroded so should come off very easily. Thanks mate will defo give it a go Quote Link to comment Share on other sites More sharing options...
RoadHog Posted July 29, 2019 Author Share Posted July 29, 2019 18 minutes ago, Jack94 said: Gotta be worth a go grinding the heatshields off to see if that cures your issue. If it doesn't then sounds like the perfect opportunity to upgrade to some high flow cats I've got torqen ones (£419) and can't fault them. Yes il defo give it a go worth a try! And thanks I did see them and wondered if they were good Quote Link to comment Share on other sites More sharing options...
msitpro Posted August 7, 2019 Share Posted August 7, 2019 On 29/07/2019 at 06:51, Jack94 said: Gotta be worth a go grinding the heatshields off to see if that cures your issue. If it doesn't then sounds like the perfect opportunity to upgrade to some high flow cats I've got torqen ones (£419) and can't fault them. Ever had these through an MOT? What were the CO and HC figures? What CPI/CPSI rating are those Torqen cats? Quote Link to comment Share on other sites More sharing options...
Jack94 Posted August 8, 2019 Share Posted August 8, 2019 12 hours ago, msitpro said: Ever had these through an MOT? What were the CO and HC figures? What CPI/CPSI rating are those Torqen cats? I've had them fitted about a year now and they went through an MOT absolutely fine in April. Can't remember the figures, @Adrian@TORQEN can probably give you more info on the cats themselves. Quote Link to comment Share on other sites More sharing options...
msitpro Posted August 8, 2019 Share Posted August 8, 2019 5 hours ago, Jack94 said: I've had them fitted about a year now and they went through an MOT absolutely fine in April. Can't remember the figures, @Adrian@TORQEN can probably give you more info on the cats themselves. Could you dig out the test cert? Curious to gather a bit of test data from people. Quote Link to comment Share on other sites More sharing options...
Jack94 Posted August 9, 2019 Share Posted August 9, 2019 On 08/08/2019 at 14:23, msitpro said: Could you dig out the test cert? Curious to gather a bit of test data from people. Sure I'll have a look for it when I get a chance, although I've just moved house so god knows where it is Quote Link to comment Share on other sites More sharing options...
