350Z Upper Coolant Hose Leak
Stock
Hi all, coolant has come out near my rad cap and upper coolant hose, sprayed itself towards the passenger side of my engine bay and down under. Nothing on drivers side, suspect upper coolant hose leak? Oil shows no signs of coolant (head gasket), and engine temps have been fine so far, coolant overflow tank is at max. Just a bit concerned as it looks like it's been there a while, little speck of coolant also visible there too, so might be spraying sporadically. The car is a HR (2007+), do they have different hoses to the DEs?
Many thanks!
Thanks Alex, do you sell the hoses complete with clamp, radiator cap and 10L of coolant? How much would I be looking at incl. postage? I assume I'd only have to do a "partial" flush of the coolant system (rad only) and not bleed the whole block.
Edited by Stock
I will have a top radiator hose and clips and rad cap in stock mate.
I no longer ship fluids so best to get the premix stuff from Nissan.
5x litres will be plenty for the radiator drain.
Just drop me a PM if I can help further.
