Fletch350 Posted July 12, 2019 Share Posted July 12, 2019 Does anyone know if dexron v1 is similar? Looking to do a gearbox fluid and filter change and can only find matic s fluid in litre sizes.car has done 72k with no record of a change.all is well with transmission at the moment just preventative maintenance. Cheers. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 12, 2019 Share Posted July 12, 2019 Save your cash, Nissan's' auto fluid is a fluid for life. However, if you still want to change the fluid then best to stick with Matic S ATF Quote Link to comment Share on other sites More sharing options...
Fletch350 Posted July 12, 2019 Author Share Posted July 12, 2019 Thanks, I've always been suspicious of "fluids for life" though, I'd prefer a long life as opposed to a trans change! Quote Link to comment Share on other sites More sharing options...
Wolfman Posted August 28, 2019 Share Posted August 28, 2019 Hi I recently did a full flush and replacement on mine. I used CASTROL TRANSMAX Z. Here is the spec sheet : https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/5318889C4CDA883380257C990001D228/$File/BPXE-9H7QZ8.pdf Its similar to Nissan where Matic Fluid D which is used by our cars. Been running it for almost 6 months now with zero issues. Hope this helps. Quote Link to comment Share on other sites More sharing options...
