Card holder removal or cubby behind handbrake
Dolley350z
In need of help.  Fitting new head unit.  Have an external usb lead I want to run into the card holder or cubby behind handbrake 2006 model how do I remove these 2 items.  Desperate for some guidance can’t find anything on the net.
Facelifted version is pretty much the same.
Pull out gear shift bit, remove the 2 uncovered screws, remove 4 screws where the heater controls are bolted in, remove 2 screws underneath the plastic clips in the cubby, pull out at the top and remove the electrics plug at the top, job done.
As above. Not a difficult job. I did it when I have mine.
