350Z VQ35DE DISMANTLING FOR SPARES: Fresh images just added:
ZMANALEX
Fresh into stock, just arrived today.
350Z VQ35DE:  first registered Nov. 2005
I will list up asap and weekly thereafter which parts are pre-sold or not available.
LIST OF PARTS SOLD:
CARBON BONNET: SOLD
CARBON REAR HATCH: SOLD
CARBON V1 REAR WING: SOLD
CARBON REAR LOUVRE: SOLD
NISMO V1 FRONT BUMPER: SOLD
FRONT NUMBER PLATE PLINTH: SOLD
FRONT CLEAR REFLECTORS: SOLD
R/H FRONT WING: SOLD
L/H FRONT WING: SOLD
ARK PERFORMANCE EXHAUST: SOLD
ARK PERFORMANCE SPORT CATS: SOLD
L/H DOOR OUTER MOULDING: SOLD
2 X WIPER ARMS: SOLD
R/H HOCKEY STICK: SOLD
L/H HOCKEY STICK: SOLD
BOTH FRONT SUSPENSION STRUTS: SOLD
BOTH REAR SHOCKS: SOLD
R/H DOOR FRAME SHELL: SOLD
L/H DOOR FRAME SHELL: SOLD
OMP RACING SEATS: SOLD
OMP RACING SEAT MOUNT SUB FRAMES: SOLD
NRG STEERING WHEEL; SOLD
NRG STEERING WHEEL QUICK RELEASE: SOLD
NRG STEERING WHEEL BOSS: SOLD
OEM CATS: SOLD
VQ35DE ENGINE: SOLD
VQ35DE  CD009 GEARBOX: SOLD.
FRONT MATS WITH 350Z MOTIF: SOLD
THICK REAR BOOT MAT WITH 350Z MOTIF: SOLD
BLUETOOTH ADAPTOR: SOLD
AIRCON COMPRESSOR: SOLD
BOSE SUB COVER: SOLD
R/H XENON; SOLD
L/H XENON: SOLD
BOTH XENON BALLASTS: SOLD
BOTH XENON IGNITORS AND BULBS: SOLD
CLOCK SPRING/SPIRAL CABLE: SOLD
COMBINATION SWITCH: SOLD
"W" BRACING: SOLD
R/H FRONT O2 SENSOR: SOLD
L/H FRONT O2 SENSOR: SOLD
R/H REAR CAT. SENSOR: SOLD
L/H REAR CAT SENSOR: SOLD
20 x INTERNAL HEX DRIVE LUG NUTS: SOLD
10 x EXTENDED WHEEL STUDS: SOLD
2 x FRONT 12MM SPACERS: SOLD
4 x WHEELS & TYRES: SOLD
1 x L/H A-PILLAR TRIM: SOLD
1 x PAS PUMP: SOLD
1 X COMPLETE SET WASHER BOTTLE HOSES AND CONNECTORS: SOLD
1 X L/H HEADLAMP WASHER PUMP: SOLD
1 X FRONT WINDSCREEN WASHER PUMP: SOLD
1 X R/H DOOR BOSE SPEAKER GRILLE: SOLD
2 X FRONT BREMBO CALIPERS: SOLD
2 X REAR BREMBO CALIPERS: SOLD
FRONT BRAKE PADS: SOLD
REAR BRAKE PADS: SOLD
FRONT AND REAR BREMBO PAD FITTING KIT: SOLD
1 X FUEL FLAP ACTUATOR: SOLD
4 X FRONT BREMBO CALIPER BOLTS AND FORM WASHERS: SOLD
4 X REAR BREMBO CALIPER BOLTS AND FORM WASHERS: SOLD
1 X REAR HUB BEARING ASSY: SOLD
1 X FRONT HUB BEARING ASSY: SOLD
1 X ASHTRAY: SOLD
1 X KEYLESS CONTROL MODULE: SOLD
1 X COOLANT FAN MOTOR: SOLD
2 X FRONT BRAKE DISCS: SOLD
2 X REAR BRAKE DISCS: SOLD
2 X FUEL DAMPERS: SOLD
2 X FRONT ABS SENSORS: SOLD
1 X ENGINE DIP STICK: SOLD
1 X COIL PACK: SOLD
2 X REAR "W" BRACING KIDNEY BRACKETS: SOLD
1 X ABS PUMP/MODULE; SOLD
1 X N/S/R TOP SUSPENSION ARM: SOLD
1 X N/S/R HUB CARRIER: SOLD
1 X N/S/R COIL SPRING: SOLD
1 X N/S/R LOWER SPRING CARRIER: SOLD
1 X N/S/R LOWER TOE ARM: SOLD
1 X N/S/R LOWER TRACTION ARM: SOLD
1 X N/S/R HUB BEARING ASSY: SOLD
1 X N/S/R BEARING SLEEVE: SOLD
1 X PAIR SUN VISORS: SOLD
1 X GEAR LEVER PLASTIC SURROUND: SOLD
1 X N/S/R GLOVE BOX TRAY: SOLD
1 X N/S/R GLOVE BOX FALSE FLOOR: SOLD
1 X HEAD LINING: SOLD
1 X DOUBLE DIN: SOLD  https://www.ebay.ie/itm/6-2-DVD-CD-Player-Car-Stereo-GPS-Sat-Nav-Bluetooth-Radio-For-Nissan-Almera-N16-/172344148076
1 X DOUBLE DIN WIRING HARNESS: SOLD
1 X DOUBLE DIN FACIA SURROUND: SOLD
2 X DOUBLE DIN SIDE FIXING BRACKETS: SOLD
1 X BATTERY FUSE LINK: SOLD
1 X L/H MIRROR GLASS AND BACKING PLATE: SOLD
1 X FRONT UNDERCARRIAGE BRACING: SOLD
1 x BATTERY COVER: SOLD
2 X INNER TRACK CONTROL ARM BOLTS/NUTS: SOLD
1 X L/H DOOR GRAB: SOLD
1 X R/H A PILLAR/DOOR SEAL: SOLD
1 X STARTER MOTOR: SOLD
2 X LOWER FRONT SHOCKER BOLTS/NUTS: SOLD
2 X LOWER REAR SHOCKER BOLTS: SOLD
2 X FRONT SWAY BAR BRACKETS: SOLD
1 X R/H DOOR MIRROR SEAL: SOLD
1 X N/S/F HUB: SOLD
1 X N/S/F SUSPENSION UPRIGHT: SOLD
1 X N/S/F INNER RACK END: SOLD
1 X N/S/F TRACK ROD END: SOLD
1 X N/S/F TRACK CONTROL ARM: SOLD
1 X N/S/F COMPRESSION ROD
1 X N/S/F SUSPENSION TOP WISHBONE: SOLD
1 X REAR STRUT BRACE COVER: SOLD
1 X O/S/R TAIL LIGHT: SOLD
1 X STEERING RACK: SOLD
1 X SERPENTINE BELT TENSIONER PULLEY: SOLD
1 X O/S/R VENT PANEL: SOLD
1 X O/S/R BOOT VENT: SOLD
1 X O/S TWEETER HOUSING: SOLD
1 X N/S TWEETER HOUSING: SOLD
1 X AIR CON BELT AJUSTING PULLEY: SOLD
1 X 0/S/R BUMPER FOG LIGHT ASSY: SOLD
1 X R/H CAM POSITION SENSOR: SOLD
1 X L/H CAM POSITION SENSOR: SOLD
1 X N/S DROP WINDOW SWITCH ASSY: SOLD
1 X THROTTLE BODY: SOLD
1 X HANDBRAKE ADJUSTER: SOLD
1 X L/H CURTAIN AIR BAG: SOLD
1 X PAIR SPORT CATS: SOLD
1 X ASH TRAY: SOLD
1 X CD009 GEARBOX: SOLD
1 X PERFORMANCE CLUTCH, CLUTCH KIT: SOLD
1 X PERFORMANCE CLUTCH SINGLE MASS FLY: SOLD
1 X AIR CON COMPRESSOR: SOLD
1 x AIR FILTER HOUSING: SOLD
1 x MAF SENSOR: SOLD
1 x CLUTCH PEDAL ASSY: SOLD
1 x CLUTCH MASTER CYL: SOLD
1 x CLUTCH HARD LINE: SOLD
1 x CLUTCH SLAVE CYL: SOLD
1 x PROP. SHAFT: SOLD
1 x BRAKE PEDAL ASSY: SOLD
1 x CENTRE CONSOLE (HANDBRAKE) SOLD
1 x STEERING COLUMN HARDWARE KIT; SOLD
1 x DOOR CHECK HARDWARE KIT: SOLD
1 x UPPER PLENUM HARDWARE KIT: SOLD
1 x HANDBRAKE SWITCH: SOLD.
2 x COIL PACKS: SOLD
1 x BOOT LOCK ACTUATOR: SOLD
2 x FRONT TOP SUSPENSION MOUNTS: SOLD
1 x N/S//F XENON HEADLAMP: SOLD
2 x BOOT PLASTICS: SOLD
1 x N/S/R ARCH REPAIR PANEL: SOLD
1 x ENGINE BAY WIRING LOOM: SOLD
1 x COIL PACK: SOLD
1 x R/H FUEL TANK SENDER UNIT: SOLD
1 x L/H FUEL TANK SENDER UNIT: SOLD
1 x HEADLAMP WASHER PUMP: SOLD
1 x XENON SELF LEVELING SENSOR: SOLD
1 x FRONT WIPER MOTOR ASSY: SOLD
1 x WASHER BOTTLE FILLER AND CAP: SOLD
1 x PAS HOSE: SOLD
1 x FRONT WIPER LINKAGE ; SOLD
1 x R/H DOOR SPEAKER: SOLD
1 X R/H EXTERIOR DOOR HANDLE: SOLD
1 X L/H EXTERIOR DOOR HANDLE: SOLD
1 X R/H/R ARCH REPAIR SECTION: SOLD
1 X L/H/R ARCH REPAIR SECTION: SOLD
1 X MAF SENSOR TUBE: SOLD
1 X ABS PUMP SWITCH: SOLD
1 X AIR CON MODULE: SOLD
1 X DASH CUP HOLDER: SOLD
1 X PAIR BONNET HINGES: SOLD
1 X VLSD SHORT STUBBY: SOLD
1 X GEARBOX BRIDAL; SOLD
1 X XENON BALLAST: SOLD
1 X AIR CON CONDENSER: SOLD
1 NISMO SPEEDO CLUSTER DIAL SET: SOLD
Poor Zed indeed Paul.
Did a few barrel rolls but fortunately, no one hurt.
Local car known to me and appears to be mechanically sound.
Just a few of the panels require a T Cut & polish and it will be good to go.: :lol:
Lol don't think the insurance company would see it that way, good job nobody got hurt
Yes, intact and available, and with OEM heated rear glass and V1 wing and all looking in great shape.
I will have a closer look at the weekend to establish if a Seibon or aftermarket hatch and if V1 is genuine Nismo or replica.
The bonnet is genuine Seibon so the hatch may be as well.
19 hours ago, Heardy said:
Looking for the large cubby hole in the centre console? Someone took mine out to put an aftermarket unit in and want to rip that out
The cubby where the nav goes, above the double din ?
21 hours ago, AntelopeSam said:
I keep coming back to this thread to look at those wheels! For some unknown reason as there rough as anything! xD
Are the backs smaller than the front or it it an illusion?
The wheels and tyres are all 18".
I can put better images up if you are interested.
The wheels are straight with no buckles or cracks, but they will require a refurb.
I still keep coming back to them!
Are they fitted with any spacers?
How much are you thinking about selling them for? I guess postage would be the real killer!
Shipping is not a problem as I would ship the wheels and tyres on a pallet.
There are no spacers on the rears and 10mm spacers on the front.
Just give me a fair offer mate and they are yours.
