Heardy Posted July 6, 2019 Share Posted July 6, 2019 Hi all Getting my alignment done on my 2004 DE and all the rear adjustable bolts are rusted/seized solid. Nissan have quoted these parts - 4 x 55226pa 4 x 55226p 4 x 55227 4 x 55269 4 x 55269a Just wondering if this is a direct replacement kit for a standard setup? Or if there is somewhere else to get them? - http://www.clarkmotorsport.co.uk/parts/Eibach-Rear-Camber-and-Toe-Bolt-Kit/5.72055K Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted July 6, 2019 Share Posted July 6, 2019 Hi mate I would 1 Quote Link to comment Share on other sites More sharing options...
Heardy Posted July 6, 2019 Author Share Posted July 6, 2019 9 minutes ago, ShortPaul said: Hi mate I would Thought I'd read something on an old post that they were no longer trading. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 6, 2019 Share Posted July 6, 2019 Plenty in stock, just drop me a PM if I can help further. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted July 6, 2019 Share Posted July 6, 2019 1 hour ago, Heardy said: Hi all Getting my alignment done on my 2004 DE and all the rear adjustable bolts are rusted/seized solid. Nissan have quoted these parts - 4 x 55226pa 4 x 55226p 4 x 55227 4 x 55269 4 x 55269a Just wondering if this is a direct replacement kit for a standard setup? Or if there is somewhere else to get them? - http://www.clarkmotorsport.co.uk/parts/Eibach-Rear-Camber-and-Toe-Bolt-Kit/5.72055K Hi buddy, To see the full part numbers, check here https://nissan.7zap.com/en/er/z/z33/5+701+65535/g/431/ Use the part numbers to search here: www.torqen.uk or direct links here: https://www.torqen.uk/nissan/350z/suspension-steering/accessories/10632-350z-nissan-oem-rear-lower-control-arm-inner-bolt-55226-al50a.html https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/10641-350z-nissan-oem-spring-bucket-seat-toe-arm-eccentric-bolt-80mm-55226-ja01c.html https://www.torqen.uk/nissan/350z/suspension-steering/accessories/10625-350z-nissan-oem-rear-upper-lower-camber-traction-control-arm-nut-55269-ag00e.html Full kit here: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/762-350z-eibach-pro-alignment-rear-camber-and-toe-bolt-kit-572055k.html Camber only: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/12517-350z-moog-rear-adjustable-alignment-cambertoe-kit-k100172.html Toe only: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/873-350z-spc-rear-toe-bolt-kit-72055.html All in stock. Quote Link to comment Share on other sites More sharing options...
Heardy Posted July 6, 2019 Author Share Posted July 6, 2019 19 minutes ago, Adrian@TORQEN said: Hi buddy, To see the full part numbers, check here https://nissan.7zap.com/en/er/z/z33/5+701+65535/g/431/ Use the part numbers to search here: www.torqen.uk or direct links here: https://www.torqen.uk/nissan/350z/suspension-steering/accessories/10632-350z-nissan-oem-rear-lower-control-arm-inner-bolt-55226-al50a.html https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/10641-350z-nissan-oem-spring-bucket-seat-toe-arm-eccentric-bolt-80mm-55226-ja01c.html https://www.torqen.uk/nissan/350z/suspension-steering/accessories/10625-350z-nissan-oem-rear-upper-lower-camber-traction-control-arm-nut-55269-ag00e.html Full kit here: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/762-350z-eibach-pro-alignment-rear-camber-and-toe-bolt-kit-572055k.html Camber only: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/12517-350z-moog-rear-adjustable-alignment-cambertoe-kit-k100172.html Toe only: https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/873-350z-spc-rear-toe-bolt-kit-72055.html All in stock. cheers for that @Adrian@TORQEN are the Eibach ones a straight swap with OEM parts, I have read that some alterations need to be done to fit these? thanks Andy Quote Link to comment Share on other sites More sharing options...
