Radders001 Posted June 22, 2019 Share Posted June 22, 2019 Hey all, stored the 370 for about 6 months. Charged battery she started ok but miss fire on one cylinder. I now have error code p1091 and p0300 (missfire). Any ideas? All fine last time she started. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 22, 2019 Share Posted June 22, 2019 This may help: P1091 Nissan Description VVEL (Variable Valve Event & Lift) is a system that controls valve event and valve lift continuously. Rotational movement of the drive shaft equipped with eccentric cam is transmitted to output cam via the rocker arm and two kinds of links to depress the intake valve. The Engine Control Module (ECM) decides the target valve lift according to the driving condition and sends the command signal to the VVEL control module. The VVEL control module controls the rotation of the control shaft using the VVEL actuator motor and changes the movement of the output cam by shifting the link supporting point. As a result, valve lift changes continuously to improve engine output and response. Power supply for the VVEL actuator motor is provided to the VVEL control module via VVEL actuator motor relay. VVEL actuator motor relay is ON/OFF controlled by the VVEL control module. In addition, when the VVEL actuator motor relay cannot be controlled by the VVEL control module for some reason, it ON/OFF controlled by ECM. Quote Link to comment Share on other sites More sharing options...
Radders001 Posted June 22, 2019 Author Share Posted June 22, 2019 Thanks, I'm wondering if the relay is sticky being stood for 6 months Quote Link to comment Share on other sites More sharing options...
