Detail engine bay
Minid
A decent APC should deal with most things, but if you get really stuck then a rag with some carb cleaner on does wonders. In terms of a bespoke degreaser, autoglym at Halfords is easy to source and seems fine to me.
I think dwell time and agitation can save quite a bit of elbow grease but some is still required! When I did mine last, I used a toothbrush, but obviously that’s aggressive for paint, depending on how fussy you are about paint in the engine bay.
I can recommend Bilt Hamber Surfex cleaner which can be diluted depending on the degree of contamination. I also use 303 aerospace coating after cleaning which helps protect the engine bay and under bonnet on my Zed.
