avado Posted June 11, 2019 Share Posted June 11, 2019 (edited) Hello guys, I need some help with this problem.Both windows not dropping a little bit when l'm going to open each door. But when I open the door and manually push the window down after that it closing perfect.I tried to reset them manually by open and closing fully the windows without success.The left window motor is soon repaired so I think the problem is not in the motors. I made a video: Kindly asking moderator to move this topic in the 350z forum. Edited June 11, 2019 by avado Quote Link to comment Share on other sites More sharing options...
davey_83 Posted June 11, 2019 Share Posted June 11, 2019 I would first check the door switches on the b posts. Then carry out a window auto up/down reset. Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 11, 2019 Share Posted June 11, 2019 As above, check the door switch (nipple). Whilst your door is open, you can press/release the switch to check if your windows are moving. I take it your window will go fully up and down without issue? If they are working well, then i would do a full reset ie removing door card Quote Link to comment Share on other sites More sharing options...
avado Posted July 11, 2019 Author Share Posted July 11, 2019 On 11/06/2019 at 10:02, veeg33 said: As above, check the door switch (nipple). Whilst your door is open, you can press/release the switch to check if your windows are moving. I take it your window will go fully up and down without issue? If they are working well, then i would do a full reset ie removing door card Finally, I find some time to check these windows again. I checked the door switches (nipples). They work perfectly. Yes, my windows go fully up and down without issue. I made a full reset of the window by removing the door card. I'm 100% sure I did this correctly because first I reset the window to open only half and after that reset it to open fully. The problem is still there! Is it possible too much dust to case this problem? I'm planning to open the door again and to clean all the crease there and after that to grease it again. My question is how this window is dropping down? Is by gravity or the motor is running a bit backwards? Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted July 11, 2019 Share Posted July 11, 2019 17 minutes ago, avado said: Finally, I find some time to check these windows again. I checked the door switches (nipples). They work perfectly. Yes, my windows go fully up and down without issue. I made a full reset of the window by removing the door card. I'm 100% sure I did this correctly because first I reset the window to open only half and after that reset it to open fully. The problem is still there! Is it possible too much dust to case this problem? I'm planning to open the door again and to clean all the crease there and after that to grease it again. My question is how this window is dropping down? Is by gravity or the motor is running a bit backwards? Hi mate he will be able to advise you on the best way to get your window repaired Quote Link to comment Share on other sites More sharing options...
veeg33 Posted July 12, 2019 Share Posted July 12, 2019 18 hours ago, avado said: Finally, I find some time to check these windows again. I checked the door switches (nipples). They work perfectly. Yes, my windows go fully up and down without issue. I made a full reset of the window by removing the door card. I'm 100% sure I did this correctly because first I reset the window to open only half and after that reset it to open fully. The problem is still there! Is it possible too much dust to case this problem? I'm planning to open the door again and to clean all the crease there and after that to grease it again. My question is how this window is dropping down? Is by gravity or the motor is running a bit backwards? If everything is moving as they should, i think the mechanism is OK but no harm greasing it again. I'm pretty sure the motor drives the window up and down, not down by gravity. IMO, i would change the motor as my next step. £25 ish from Ebay specials. Make sure you get one with a reset button on the motor. Plenty on sale without the button Quote Link to comment Share on other sites More sharing options...
avado Posted July 12, 2019 Author Share Posted July 12, 2019 2 hours ago, veeg33 said: If everything is moving as they should, i think the mechanism is OK but no harm greasing it again. I'm pretty sure the motor drives the window up and down, not down by gravity. IMO, i would change the motor as my next step. £25 ish from Ebay specials. Make sure you get one with a reset button on the motor. Plenty on sale without the button Did you buy some motor from ebay? can you send me a link, because there are too many fake motors on the market? Quote Link to comment Share on other sites More sharing options...
veeg33 Posted July 12, 2019 Share Posted July 12, 2019 3 hours ago, avado said: Did you buy some motor from ebay? can you send me a link, because there are too many fake motors on the market? This is the seller i got it from --> https://www.ebay.co.uk/itm/New-Window-Regulator-Motor-Front-Left-For-Nissan-350Z-Z33-Skyline-V35-2002-2009/183510741412?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Don't bothered with the instruction that comes with it. And if you do remove the motor, i find it handy by using lots of masking tape to hold your current mirror in position. This should save you from removing it, placing it in a safe place and putting it back after you swapped the motor. Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted July 12, 2019 Share Posted July 12, 2019 1 hour ago, veeg33 said: This is the seller i got it from --> https://www.ebay.co.uk/itm/New-Window-Regulator-Motor-Front-Left-For-Nissan-350Z-Z33-Skyline-V35-2002-2009/183510741412?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Don't bothered with the instruction that comes with it. And if you do remove the motor, i find it handy by using lots of masking tape to hold your current mirror in position. This should save you from removing it, placing it in a safe place and putting it back after you swapped the motor. Two pairs of hands are best for this job, imo Quote Link to comment Share on other sites More sharing options...
