Minid Posted June 3, 2019 Share Posted June 3, 2019 Hi all, advice before I go to my nearest nissan dealer. Master key not activating central locking. Changed battery nothing. However spare works fine. Previous owner changed battery, not sure if that maybe the problem, but surely that would affect the 2nd key as well. Any help please. Previous owner stated they would pay for any new key if needed. Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 3, 2019 Share Posted June 3, 2019 Did the master key you have worked before or you have been sold with a faulty key? Few things to check before needing a new key (£150-£250 each). 1.) Try pairing it again using this procedure (i think you'll need to reprogram both else the spare key might not work anymore)--> 2.) If the above failed, you probably have a faulty key. Get a 2nd hand key from Ebay or car breaker, transfer the key blade and immobiliser block. Then you'll need to reprogram it again using method above. 3.) If both the above failed, time to get a new key from Nissan stealership or car locksmiths. Quote Link to comment Share on other sites More sharing options...
Minid Posted June 3, 2019 Author Share Posted June 3, 2019 No the master did not work as I got the call from the previous owner with a new set of batteries. I swapped the batteries today from the spare, the spare again worked but not the master Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 3, 2019 Share Posted June 3, 2019 Master key will need repairing again if the battery has been dead/out for a while. Follow the procedure above and report back. Quote Link to comment Share on other sites More sharing options...
Minid Posted June 3, 2019 Author Share Posted June 3, 2019 Get to step 7 and warning lights don't flash for successful programming. Now spare does not work, tried doing spare again and gets to step 7 and no joy, great! Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted June 3, 2019 Share Posted June 3, 2019 3 hours ago, Minid said: Get to step 7 and warning lights don't flash for successful programming. Now spare does not work, tried doing spare again and gets to step 7 and no joy, great! I would go to a car locksmith definitely not main stealer, Timpsons should be able to sort a new key if it is needed Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 4, 2019 Share Posted June 4, 2019 11 hours ago, Minid said: Get to step 7 and warning lights don't flash for successful programming. Now spare does not work, tried doing spare again and gets to step 7 and no joy, great! Try a few times and eventually you'll get there. They are a pain most of the time to get it correct. Try again - I used the reprogramming diagram further down the thread --> I didn't check if they are the same but works for me in a UK car. Is your JDM or UK? For master key - Check if any battery leakage and bad contact. That might solve it. Quote Link to comment Share on other sites More sharing options...
Minid Posted June 4, 2019 Author Share Posted June 4, 2019 Autolox are coming out tomorrow cheaper than nissan. Brand new batteries in both keys tried so many times. Lights refuse to flash confirming programming successful. Should be sorted tomorrow. Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 5, 2019 Share Posted June 5, 2019 hopefully you are all sorted! Quote Link to comment Share on other sites More sharing options...
Minid Posted June 5, 2019 Author Share Posted June 5, 2019 Came out and sorted. Both keys sorted for £75. Quote Link to comment Share on other sites More sharing options...
FrancesHolland Posted August 7, 2019 Share Posted August 7, 2019 Mine one charged much £105 has been charged by locksmith elizabeth nj for both keys. Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted August 7, 2019 Share Posted August 7, 2019 Timpsons replaced my battery in key fob then re synced the key free of charge Quote Link to comment Share on other sites More sharing options...
TysonWheeler Posted May 18, 2020 Share Posted May 18, 2020 Car locksmith near me also replaced battery and synced it for free. Quote Link to comment Share on other sites More sharing options...
WilliamDamian Posted June 8, 2020 Share Posted June 8, 2020 On 07/08/2019 at 21:08, ShortPaul said: Timpsons replaced my battery in key fob then re synced the key free of charge Thank, i will also change my battery and sync key with the help of a locksmith. 1 Quote Link to comment Share on other sites More sharing options...
Mikey_S Posted June 8, 2020 Share Posted June 8, 2020 spam accounts for locksmiths eh...... Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted June 8, 2020 Share Posted June 8, 2020 Timpsons they will sort it Quote Link to comment Share on other sites More sharing options...
