PoiZen Posted May 31, 2019 Share Posted May 31, 2019 Hi all. I’ve replaced my spiral cable on my 350 and unfortunately this has upset my steering angle sensor and put my tcs and slip light on (not a bad thing always skids now) but I like things to function as they should. I downloaded Nissan DataScan II but unfortunately it won’t connect to my abs Ecu to reset the angle sensor. Is there another way to do this or do I have to go see the stealership ? Thanks mical Quote Link to comment Share on other sites More sharing options...
PoiZen Posted May 31, 2019 Author Share Posted May 31, 2019 Just been quoted from the dealer £58 to reset it Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted May 31, 2019 Share Posted May 31, 2019 4 hours ago, PoiZen said: Hi all. I’ve replaced my spiral cable on my 350 and unfortunately this has upset my steering angle sensor and put my tcs and slip light on (not a bad thing always skids now) but I like things to function as they should. I downloaded Nissan DataScan II but unfortunately it won’t connect to my abs Ecu to reset the angle sensor. Is there another way to do this or do I have to go see the stealership ? Thanks mical I wouldn't go to main stealer, I would Quote Link to comment Share on other sites More sharing options...
PoiZen Posted May 31, 2019 Author Share Posted May 31, 2019 Thanks for the suggestion. But great news I got my DataScan II to work was a coms issue sensor reset and all happy again 1 Quote Link to comment Share on other sites More sharing options...
Arun730 Posted January 21, 2021 Share Posted January 21, 2021 @PoiZen what Hex ID did you use in communication settings for the abs parameter? and where did you get your adapter cable from cos i think i'm having issues with mine. Cheers Quote Link to comment Share on other sites More sharing options...
