2003 UK 350Z Breaking for Parts
2 hours ago, pagan said:
I don't suppose you have the elec. relays for the rad fans in the fuse box under the battery cover.?
Yeah
2 hours ago, Colin747 said:
Would you consider selling just the front Brembo callipers?
Yeah if the price is right
Bonnet
Passenger Side window motor (Clip Broken)
ESP Yaw Rate module
Rear Speaker Cover
Passenger side window
Passenger door weather strip
Drivers Door Handle
Interior Carpet
ECU
Hi Ian,
Are you selling the washer fluid reservoir? If so what's your price please?
Also interested in if they're available:
  • Centre console coin store
  • Differential (condition?)
Cheers,
James
Updated with more sold parts, still lots more available - if you dont see what you want, ask - i probably have it :)
Also, if anyone wants the shell for free - they are welcome to it. You just need to collect it from South Wales W/C 12th August.
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
list of everything left below, if anyone wanted to come and collect the whole lot, I'd do you a very good deal ;)
  • Keyless Entry Unit
  • Boot weight x2
  • Relay Cover
  • Control Unit 28550CD700
  • RHS Air Duct
  • RHS "Z Vent"
  • Passenger side interior door handle
  • Passenger side door arm rest
  • Footrest
  • Air con ECU module
  • Drivers side interior door handle
  • Oil filter housing
  • Rear cubby (broken door)
  • Fuel Rails
  • Air bag module
  • Horns
  • Drivers side knee pad
  • Upper driver side dashpanel
  • Passenger side window regulator
  • Brake fluid surround
  • Wiper arm mechanism
  • Strut Brace
  • Upper Plenum Chamber x 2
  • Drivers side kick panel
  • Boot foam
  • Front Crash Bar
  • Front bumper foam
  • Tool Kit
  • Rear boot corner plastics x2
  • Dashboard
  • Passenger side door card
  • Transmission mount
  • Relay fuse box cover
  • Petrol cap switch
  • Headlight washer switch
  • clear side indicators
  • OEM radiator Cap
  • Bonnet release handle
  • ESP switch
  • radiator fan assembly
  • Brake fluid resevoir tank
  • intake pipe
  • ABS pump
  • heater matrix
  • Right Rear Trim Panel Cover 84940CD000
  • left Rear Trim Panel Cover 84940CD000
  • PAS Oil cooler
  • Front bumper
  • Rear Bumper
  • Side skirts
  • Rear brembo calipers
Im looking for a left rear Brembo calliper if your willing to split?
edit:
Also looking for the bolts for the caliper and a nut for securing the rear suspension subframe to the car.
edit 2:
Sorry please ignore the above, I have managed to source elsewhere
Edited by Mack
  • 3 weeks later...
