Clutch pedal only comes back half way and have to use strength to get into gear. Help?
P7ICE
I’ve have this problem, replaced the throw out bearing (was going bad), machined the flywheel, changed clutch, changed master and slave, and new fluid and new line but I’m still running into the same problem with the clutch sticking halfway down and have to use strength just to get it into gear. Any suggestions? It’s a 2005 350z
Edited by P7ICE
Providing that all the parts that you have replaced/machined are good then all it will require is a proper bleed.
You simply have air in the hydraulic system.
You can also adjust the pedal, however that is not the root cause.
