Shakesheff17 Posted May 5, 2019 Share Posted May 5, 2019 Due a oil filter change In the next couple weeks and was looking at getting the p1 service kit from tarmac sportz, you get the filter magnetic drain plug and 5L of 5w 30.... my question is what is the oil capacity after it’s been drained? 5L won’t be enough will it Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted May 5, 2019 Share Posted May 5, 2019 5 ltr will be fine, they take approx 4.7 ltr hope this helps Quote Link to comment Share on other sites More sharing options...
Stock Posted May 5, 2019 Share Posted May 5, 2019 Did mine earlier, sucked the excess oil out through the dipstick pipe using an oil pump as well, filled up with a 5L drum and had a little bit left over at the end. You can use any decent SN rated oil. Drain plug should be reusable. Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted May 6, 2019 Author Share Posted May 6, 2019 Cheers lads ! Quote Link to comment Share on other sites More sharing options...
