Akumanozetto Posted April 27, 2019 Share Posted April 27, 2019 When i bought my 370z a few months ago. i noticed that whenever i press the brake (especially when doing 50 mph above) the steering shakes a lot. A few days later, I went back to the dealer and had the rotor changed. Yet, since last week, the problem was back again. I have had the rotors, pads and calipers checked but none of them seems causing the problem. has anyone had this problem before? Quote Link to comment Share on other sites More sharing options...
andy james Posted April 27, 2019 Share Posted April 27, 2019 23 minutes ago, Akumanozetto said: When i bought my 370z a few months ago. i noticed that whenever i press the brake (especially when doing 50 mph above) the steering shakes a lot. A few days later, I went back to the dealer and had the rotor changed. Yet, since last week, the problem was back again. I have had the rotors, pads and calipers checked but none of them seems causing the problem. has anyone had this problem before? Did they put new pads on with the new rotors? 1 Quote Link to comment Share on other sites More sharing options...
Akumanozetto Posted April 27, 2019 Author Share Posted April 27, 2019 25 minutes ago, andy james said: Did they put new pads on with the new rotors? Nah, just the rotor. The pad was ok 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 27, 2019 Share Posted April 27, 2019 New pads should always be fitted when replacing the rotors. Have a read here: https://www.google.co.uk/search?source=hp&ei=18TEXN7yKumq0PEPw5qQ4AY&q=disc+brake+rotor+thickness+variation&oq=Disc+thickness+variation&gs_l=psy-ab.1.2.0l2j0i22i30.2233.9609..17107...0.0..0.492.10373.3-6j18......0....1..gws-wiz.....0..0i131j0i10j0i22i10i30.91zrTL55d3Y Quote Link to comment Share on other sites More sharing options...
Akumanozetto Posted April 27, 2019 Author Share Posted April 27, 2019 2 hours ago, ZMANALEX said: New pads should always be fitted when replacing the rotors. Have a read here: https://www.google.co.uk/search?source=hp&ei=18TEXN7yKumq0PEPw5qQ4AY&q=disc+brake+rotor+thickness+variation&oq=Disc+thickness+variation&gs_l=psy-ab.1.2.0l2j0i22i30.2233.9609..17107...0.0..0.492.10373.3-6j18......0....1..gws-wiz.....0..0i131j0i10j0i22i10i30.91zrTL55d3Y Thanks, i will see if it works Quote Link to comment Share on other sites More sharing options...
z350convert Posted June 2, 2021 Share Posted June 2, 2021 I hope this thread is still live. I have a similar issue with vibration through steering when braking from 50mph and over. I had front discs and pads changed last year, after which the problem seemed to start. I’ve read on here that if the new rotors are not aligned perfectly it can cause a vibration. The garage I used may not have been up to the job - it’s a possibility. What do the wise say? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 3, 2021 Share Posted June 3, 2021 I think that your assumption is correct and that you either have pad deposits or are suffering from the classic DTV I am afraid. Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted June 3, 2021 Share Posted June 3, 2021 12 hours ago, z350convert said: I hope this thread is still live. I have a similar issue with vibration through steering when braking from 50mph and over. I had front discs and pads changed last year, after which the problem seemed to start. I’ve read on here that if the new rotors are not aligned perfectly it can cause a vibration. The garage I used may not have been up to the job - it’s a possibility. What do the wise say? Were these bedded in correctly? If not, that could be your issue: https://torqen.uk/docs/TORQEN-brake-bedding.pdf Quote Link to comment Share on other sites More sharing options...
GranTurismoEra Posted June 3, 2021 Share Posted June 3, 2021 (edited) For me it was cheaper to get the discs and alloys skimmed by an engineer than spend hundreds on new discs and pads. Solved the problem for me Edited June 3, 2021 by GranTurismoEra 1 Quote Link to comment Share on other sites More sharing options...
z350convert Posted June 4, 2021 Share Posted June 4, 2021 My discs and pads are new but I didn’t bed them in properly as detailed on here, I just used them gently for a bit. ive been in touch with Abbey Motorsport and they think it might be excessive run out on the disc, they are going to measure it. Quote Link to comment Share on other sites More sharing options...
z350convert Posted June 4, 2021 Share Posted June 4, 2021 On 03/06/2021 at 12:26, Coz@TORQEN said: Were these bedded in correctly? If not, that could be your issue: https://torqen.uk/docs/TORQEN-brake-bedding.pdf No, I just did what I do normally which was to go easy on them. Quote Link to comment Share on other sites More sharing options...
