Shakesheff17 Posted April 27, 2019 Share Posted April 27, 2019 Hi I’m new to the forum had my 350z 2weeks So all was well for the first 2 weeks and yesterday driving home the temp went right up to by the red pulled over and couldn’t see a leak so drove it the 5mile left back home. Topped up after it cooled down with coolant and left overnight. took it for a drive then after 15mins or so it stated to rise on the temp over halfway again, got out and now I could see I was leaking a fair amount of coolant from the drivers side front of the car could not see the cause. Radiator was dry coolant expansion was dry looked to be wet at the bottom and running from behind the under tray drivers side. Side notes are no heat from heaters either. Any idea on the part/hose etc that’s failed? Many thanks Quote Link to comment Share on other sites More sharing options...
kbad Posted April 27, 2019 Share Posted April 27, 2019 Hello and welcome along, I am sure someone on here will perhaps shed some light on this soon Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted April 27, 2019 Author Share Posted April 27, 2019 Thanks for having me, engine spec is 06 revup 46000miles, thinking it’s a split hose that’s only leaks under pressure but would be good if anyone knew a location I should expect it to be Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted April 27, 2019 Share Posted April 27, 2019 Hi and welcome along. It could be your fans not working. Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted April 27, 2019 Author Share Posted April 27, 2019 Both fans kick in as it rises on the temp gauge so I’ve ruled that out Quote Link to comment Share on other sites More sharing options...
Whitevanman Posted April 27, 2019 Share Posted April 27, 2019 hopefully its just a split hose , is there any sludge around the expansion tank or around the radiator cap? if in any doubt get it to the garage, dont keep over heating it..... Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted April 27, 2019 Author Share Posted April 27, 2019 No sludge mayo, no oil in the coolant , no vapour from exhaust so I’m ruling head gasket out as I’m sure I’d have at least one of them symptoms. And would a HG failure leave a pool of coolant while running, I have limited knowledge but I don’t think it would well I hope not! Ive just dropped it off at my local indie but there not in till Monday now. Am am I right in thinking because there’s coolant escaping and there’s no heat from heater that the coolant isn’t reaching around the engine to keep it at normal running temp. im hoping it’s a cheap fix like a clip or hose , I suppose it could be a water pump too? Great start to Z ownership! Reliability coupe was a selling point for me , that and they are the best looking on the road in my opinion Quote Link to comment Share on other sites More sharing options...
Peeege Posted April 28, 2019 Share Posted April 28, 2019 Hi and welcome, hopefully nothing serious and your'e up and running again soon Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 28, 2019 Share Posted April 28, 2019 Fill up with coolant and bleed system to get all the air out and then pressure test system to trace the leak. If you are lucky then you may be able to pressure test without the time-consuming bleeding procedure, however, you will have to bleed properly once you have rectified the fault Quote Link to comment Share on other sites More sharing options...
pintopete58 Posted April 28, 2019 Share Posted April 28, 2019 Hi sounds like thermastat Quote Link to comment Share on other sites More sharing options...
Andyw08 Posted April 28, 2019 Share Posted April 28, 2019 Welcome, I'm new to and got problems, just to make you feel like you're not the only one ha ha but I'd fill with water/coolant and pressure test it, most garages with have the tool you need Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted April 30, 2019 Author Share Posted April 30, 2019 Hi and update a small leak was found on the road hose that’s been rectified , but still continues to overheat, losing all my coolant through the overflow, we’ve noticed there’s no seal on the overflow so getting a cap today but would this really be the source to my problem. The car is holding pressure in the system as it’s been tested. any thoughts I’m swaying towards thermostat possibly? Quote Link to comment Share on other sites More sharing options...
pintopete58 Posted April 30, 2019 Share Posted April 30, 2019 Thats the first thing i would change after sorting leaks it's not expensive Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 30, 2019 Share Posted April 30, 2019 The stat is very easy to remove and check, however as stated before I am leaning towards an air lock within the coolant system. Did you bleed the system properly as per the Nissan workshop manual to get rid of all the air? This issue has been covered many times in the past on here and I posted a bleed guide up previously. Other common issues are fan motor failure and choked rad. However 99.9% of the time it is an air lock. Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted April 30, 2019 Author Share Posted April 30, 2019 Hi yeah the system was bled after being topped up. Would the overfill tank not having a secure seal cause air to leak in causing more air issues, the cap of being replaced today and itl be run after. Quote Link to comment Share on other sites More sharing options...
StormWhite Posted April 30, 2019 Share Posted April 30, 2019 (edited) On 30/04/2019 at 09:02, Shakesheff17 said: Hi yeah the system was bled after being topped up. Would the overfill tank not having a secure seal cause air to leak in causing more air issues, the cap of being replaced today and itl be run after. Expand A poor seal or no seal on the overflow tank would cause the coolant to boil at a lower temperature. Hopefully a new cap will sort out your issue. Edited April 30, 2019 by StormWhite Quote Link to comment Share on other sites More sharing options...
Payco Posted April 30, 2019 Share Posted April 30, 2019 Have you bled it on the hose (cleared any airlocks). There is a screw tee piece on the hose you can loosen to bleed the air. I would do this with the engine running. Quote Link to comment Share on other sites More sharing options...
Shakesheff17 Posted April 30, 2019 Author Share Posted April 30, 2019 (edited) All sorted no overheating and no leaks, just wanna thank everyone on here for there help, turns out there was a slight leak that was fixed then after it continued to overheat the cap was replaced on the overfill tank ,they bled the system and took them 3 hours to get every little bit of air out. Low and behold I now have hot air coming through heaters and no overheating or leaks once again thanks I’m off to stretch her legs ! Edited April 30, 2019 by Shakesheff17 Quote Link to comment Share on other sites More sharing options...
