How do you delete posts
It’s a very reasonable question.
In short, you can’t as a Member, if you feel the need to correct something, you can edit it. If you really must have it removed, you can either PM someone on the team or report the post and ask for it to be deleted.
  • Like 3
  • 2 years later...
  • 4 months later...
  On 16/05/2022 at 06:50, pintopete58 said:
How do you clear your pms
Expand
The long, but careful way, is to go into each one and hit options in the top right and delete conversation. The easier way to do it en masse, is to use the check box on the left and then at the bottom of the screen you should a little pop up with a bin in it, click that.
