Umster Posted April 24, 2019 Share Posted April 24, 2019 So I bought a 4th light, used from a 370Z owner and have finally come around to installing it. Decided to be sensible and test the light with a 9v cell. There are 4 wires, black (earth/negative), red (running light/positive), green (brake light/positive), white (reverse light/positive). The running and brake lights both work when connected to the small cell. The reverse light doesn't however. I used a multimeter to test the continuity and struggled but when checking the resistance, I got a reading. I also cut wire further down just to check it wasn't a frayed section of wire. I've decided to go ahead and just put the light in and use it solely as a foglight in the interim. Testing the OEM setup is something I missed when buying the car and before removing the OEM light so clever me has nothing to benchmark my next issue to. When I flick the fog lights on, the 4th light turns on and then turns off! Not sure how or why or what but a little help is needed. My issue now is, what do I check and do next? For the foglight issue and for the reverse light. Few photos below of the light. Quote Link to comment Share on other sites More sharing options...
wvSTUwv Posted April 24, 2019 Share Posted April 24, 2019 I had the same problem with my fog light 1 day before my MOT when I turned it on it quickly turned itself off. The problem with mine was a poor connection on the new fog light wire to the original wire. Hopefully you can get it sorted. I did post a video on the Facebook group asking for people suggestions Quote Link to comment Share on other sites More sharing options...
Umster Posted April 25, 2019 Author Share Posted April 25, 2019 15 hours ago, wvSTUwv said: The problem with mine was a poor connection on the new fog light wire to the original wire. This helped me massively. In the end I have found out the following and hopefully it helps others. 1. Reverse light requires 12v. Testing with a 9v battery is useless. 2. Loose connections happen, buy a multimeter/testing screwdriver and use it. I've got it all working albeit just as a fog light and reverse light. Perfect for me. 1 Quote Link to comment Share on other sites More sharing options...
