Advice Needed: Wiring Diagram - Footwell LEDs
davidv10
Im looking to put in footwell LEDs that will come on with the sidelights. I have found from the US forums that you can tap in to the heated seats off the brown plug under the cup holder. You just tap in to the red wire there. I will also have a master on/off switch as well.
Can someone confirm/advise on the below wiring diagram i have made for this?
The only thing i wasnt sure about was having to put in another fuse, but i guessed that the heated seats power would already have one further down?
Thanks in advance.
Edited by davidv10
  On 20/04/2019 at 12:22, Mopedmark said:
You can buy a kit from Ebay for about a tenner that plugs into the fag lighter with an on off switch it also has a little remote so you can change the colours simple
Expand
Thanks for the reply. Yeh i know you can, but want them to seamlessly tie in with the sidelights, and also dont want anything sticking out of the cigarette lighter. Want it to look as oem and tidy with no cables or plugs as possible.
