hotrain69 Posted April 4, 2019 Share Posted April 4, 2019 Hi all, the light on the AC dial/switch seems to have given up so now I can't tell if it is on or not. Pretty it is just the light that is not working and the actual dial is still working. So question is, is there an easy/obvious way that I can easily tell whether the AC is on or not? I was thinking for some reason that when the dial is turned on from the "off" position, the AC is default on? Or am I dreaming?? Cheers. Quote Link to comment Share on other sites More sharing options...
Kryptek49 Posted April 4, 2019 Share Posted April 4, 2019 The cold air might give it away IIRC, mine turns on as soon as I turn the car on, regardless of if the dial is set to off. I'll double check after work if no-one else can confirm it. Quote Link to comment Share on other sites More sharing options...
hotrain69 Posted April 4, 2019 Author Share Posted April 4, 2019 6 minutes ago, Kryptek49 said: The cold air might give it away IIRC, mine turns on as soon as I turn the car on, regardless of if the dial is set to off. I'll double check after work if no-one else can confirm it. I should've expected that one!! That's strange though, the thing that is certain on mine was when right hand dial was off, there is no light for AC. Just can't remember if then it comes on as default when I turn it on or not!! Do let me know when you get a chance to check. Cheers. Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 4, 2019 Share Posted April 4, 2019 If you haven't got the owners manual, see pages 4.9 - 4.11 here that might help?: http://www.vadennissanservicecontracts.com/owners-manual/nissan/2007-Nissan-350Z.pdf Quote Link to comment Share on other sites More sharing options...
OnlyAfro Posted April 4, 2019 Share Posted April 4, 2019 AC will turn on when you set it to blow at the windscreen (all the way to the right) - recirc should also engage. Quote Link to comment Share on other sites More sharing options...
hotrain69 Posted April 4, 2019 Author Share Posted April 4, 2019 This is great stuff guys. Thanks alot . I think I was partly right! hopefully take some of the guess work out of it now.. Cheers Quote Link to comment Share on other sites More sharing options...
