Engine Bay Clean
Mike k-g
I used a jet wash from about a foot away, being sure not to stay in the same place but to keep the jet moving.
Rinse down
All purpose cleaner 5:1 *foaming spray nozzle
Various brushes to agitate
Jet wash off
Dry any surface and pooling water
At least half hour drive to help dry the engine bay.
The next day a trim dressing of choice.
Tip - do the underside of the bonnet just before the engine final jet off.
Edited by davey_83
Surely the 370Z is gonna need some electronics covering up? I'm not too confident in dousing it with water, granted its a mechanical car (compared to zee German motors) but surely a few of the sensors will need hiding away first?
Also worth noting to be careful around the air filter - especially if you've changed to an induction kit!! - and the battery. But otherwise, you're pretty much good to go nuts, within reason.
If you're not confident with a pressure washer, a steam clear is "safer" and equally as effective, or a hose instead of a pressure washer is "safer" but less effective.
