Lowered
Mike k-g
Going to look at a 370 today ..but 1 thing im not happy
about its lowered on 30mm springs ..didnt really want this..
question is could this be to low and will i have problems with speed bumps?
also any ideas the cost in putting back to stock suspension?
Thanks Mike
Hey Payco could you point me in the right direction for some Teins S Springs like the
 ones you use on your car?  might have to get these then look at getting them fitted  by someone.
 Any ideas on cost to fit  roughley?
Thanks Mike Kg
Hi mike, contact tarmacsportz, they are a member trader on here. You could talk to buster or chris they will sort you out. On the 370z they give a 20mm and 25mm drop iirc.
edit:- they give 30mm all round I think it's the eibach springs that give the drop in the above.
Edited by Andy_Muxlow
Thanks Mike Kg
Contact Chris at Tarmac Sportz mate. Under Pro Traders on here. Its a couple of hours labour for a garage to fit. The drop isn't a severe as 30mm on the Tein S. Chris will advise you.
Edited by Payco
update
