Changing clutch fluid question
Kryptek49
The clutch fluid on my HR is looking very brown, so I've just ordered some Motul RBF 600 so I can flush it out myself next week.
I've seen in a few videos of people changing fluid in a 370z (same as HR i believe) that they drained the reservoir completely and then cleaned inside it with a lint-free cloth.
Doesn't this introduce air into the system though? Which then causes alot of problems trying to bleed the clutch?
If I don't drain the reservoir fully, how am I meant to clean the dirt from inside the reservoir?
Thanks in advance
Siphon 80% of the old fluid from the reservoir using a syringe.
Fill the reservoir with fresh fluid and using a small toothbrush gently scrub the inside of the reservoir.
Siphon again leaving about 20% of fluid in the reservoir.
Top up and bleed.
3 man operation.
1 on the pedal, 1 on the reservoir and 1 on the bleed nipple.
DO NOT LET THE RESERVOIR RUN DRY
