Heater/Aircon/Fan controls not working
EvansJD2112
Started my 2018 370z this morning.
Fan came on then noticed I couldn't alter temperature or fan speed.
No controls on the heater/Aircon panel are working.
Fan is still on and it feels like the Aircon is working because I was blooming freezing by the time I got to work.
Hopefully just a fuse.
Whereabouts is the fuse for the Aircon/heater controls?
The ribbon cable on the 350z is fairly fragile, if it's damaged the fans can just blast out air without you being able to stop them.
Not sure if the 370z uses the same kind of cable, could it have been dislodged or damaged?
Other option could be that you've got the fans set to auto?
If not, disconnecting the battery should have the same effect as pulling the fuse.
