Sam9901 Posted March 10, 2019 Share Posted March 10, 2019 Just got my DEPO headlights and wondering if anyone has had any issues with them either during install or after. Is there anything that needs doing before I install other than swapping ballast and bulbs? Also has anyone had issues with the beam pattern on MOT's or during use due to them being LHD spec and is there anyway to overcome this? Thanks guys! Quote Link to comment Share on other sites More sharing options...
Sargara Posted March 10, 2019 Share Posted March 10, 2019 No install was straight plug and play with my DE. So long as your car has xenons/hids theres nothing required. The only issue i had with mine was the access hole on the back of the housing. The DEPO construction just isn't as good as OEM sorry, the rubber seal around the cap gets hot and distorts/stretches and doesn't make a good seal so I started getting condensation in both. The tabs are also fragile, smaller than OEM and easily bent. You can tell by how much flex the housings have they've cut some corners in materials. Quote Link to comment Share on other sites More sharing options...
