Rocker cover or gasket failed? Oil on plug
michaelgordon
I change my spark plugs last weekend and one of them had oil on i was told its either the rocker cover or the gasket has failed.    It was only one plug the one closest to the bulkhead on the drivers side.  Im getting the gallery gaskets changed in a couple of weeks, would it be worth just changing the gasket while its getting done or will it likely be the actual cover?
It will be the oil seal which is part of the rocker cover.
You can replace the seals, however, I have in stock new covers which come in cheaper than the oil seal kit.
Just drop me a PM if I can help further:
