walkernet Posted February 15, 2019 Share Posted February 15, 2019 I have an intermittent issue with the passenger side window on my 350Z roadster. It has specific symptoms, so I'm wondering if anyone can help me narrow down where the cause could lie. * Window stops working - wont go down. * No click from within the door which you normally hear when it's working * Wont go down using the switch on drivers or passenger door, so presumably not the switch * When stuck in the up position, if you open the roof, the window immediately goes down as it should, but once down, wont go up again, so presumably not the motor. * So far, after numerous roof open/close operations (and window still being stuck), i've eventually got it to go up again, and then it continues to work, until the next time it fails. * Does not appear to be associated with the window "lock" button on the drive side. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 15, 2019 Share Posted February 15, 2019 Probably the motor, even though you appear to have discounted it. Fully working preowned motors are in stock for Roadsters at the minute if required. Just drop me a PM if I can help further. Quote Link to comment Share on other sites More sharing options...
