Facelift steering wheel controls
Jack94
350z facelift steering wheel controls for audio and cruise control.
They're in used condition with a few scratches and a bit of lacquer peeling, ideal for wrapping/painting/hydrodipping etc.
I think these can be fitted as an upgrade to pre-facelift cars or ones that didn't have the controls from the factory (although I'm not sure if other parts are needed for that too).
£50 posted or £45 collected from Banbury.
On 21/02/2019 at 20:06, jordank said:
Are these plug and play on a zed without steering wheel volume controls ?
From the little bit of research I've just done looks like if your car is a a facelift then they're simply plug and play.
If you've got a pre-facelift they'll work but won't illuminate unless you run in an extra wire.
https://my350z.com/forum/exterior-and-interior/614805-changing-steering-wheel-controls-from-04-to-07-a.html
https://www.z1motorsports.com/instrument-cluster-and-gauges/nissan/oem-350z-cruise-control-retrofit-kit-06-p-11628.html
