Air vent removal
MONKEYSOCKS
This is probably posted in the wrong section, so apologies, but basically, long story short. My 3 year old daughter put a parking token down my passenger air vent. Can get it with a long grabber that I got off eBay, but can't get it back through the vent. So looks like I need to remove the vent. Is it just a matter of unscrewing the bolts behind the z emblem vent?
You mean the Z vent that’s hidden when the door is closed? It just pops out. Slide a flat trim removal tool under the bottom and it’ll pop out. If you don’t have trim removal tools than you can use a flat bladed screwdriver but be careful to avoid scratching the dash.
The bolt you you can see through the vent holds in the dash.
Edit: google search ;) https://goo.gl/images/bqXsFc
Edited by baileydom
