Recon engine
Liddell
Yes we carry a rebuilt stock motor. What is wrong with your motor please?
The main items that needs needs to be serviceable will be the crank if the crank needs replacing this adds to the cost of the recon motor.
exchange engine is £2000 inc vat  as long as you engine is serviceable
thanks
Hi mark,
thanks for the response, could I have some more details on the engine, as very interested.
is it the 06 DE REV-UP (7000rpm) engine?
what work was done as part of the rebuild?
Ideally it is so it’s a like for like :)
thanks,
james
5 minutes ago, Mark@Abbey m/s said:
We feel the DE is a better motor. We can transfer a DE tune across into the REV UP ecu and turn off the DTC that will be required when fitting a DE motor into a REV UP
I see! I’m definitely interested. Could I give you a call tomorrow morning to discuss more?
thanks,
james
