neo Posted January 14, 2019 Share Posted January 14, 2019 (edited) Hi Guys, Since Saturday there's been a SOLID yellow key warning light on my dashboard, everything works as it should, opening doors, starting car etc, tried the spare fob still the same, left keys in the cup holder instead of pocket, even tried the fobgina slot and still the light is there, a google search says it could be steering lock fault but thought they were all sorted back in 2009-10, mine is now out of warranty and i don't fancy being stuck in the middle of no where if it fails to start the keyfob battery was changed last year, surely it cant be that as there's been no other warning messages, other than trying a new battery is there anything else i can try or is it a Nissan job Edited August 21, 2019 by neo Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 14, 2019 Share Posted January 14, 2019 Not sure if it's the steering lock but pull the fuse if you haven't already to avoid that Quote Link to comment Share on other sites More sharing options...
neo Posted January 14, 2019 Author Share Posted January 14, 2019 Thanks for the reply, which fuse is it and wheres the location Quote Link to comment Share on other sites More sharing options...
Davectr Posted January 14, 2019 Share Posted January 14, 2019 It’s in the engine bay on the left side as you look at the car from the front (drivers side). Do a search on here or YouTube and there’s guides on how to do it. It quite easy Quote Link to comment Share on other sites More sharing options...
neo Posted January 14, 2019 Author Share Posted January 14, 2019 Thanks again just been out to the car, there are no lights on the fobgina hole, there should be one top and bottom ??? maybe the port as gone bad, hence the light ? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 14, 2019 Share Posted January 14, 2019 4 hours ago, neo said: Thanks for the reply, which fuse is it and wheres the location 1 Quote Link to comment Share on other sites More sharing options...
neo Posted January 15, 2019 Author Share Posted January 15, 2019 Would this code reader work ??? https://www.amazon.co.uk/dp/B013DSTPWY/ref=cm_sw_r_cp_apa_i_mwxpCb60NFJ0S Quote Link to comment Share on other sites More sharing options...
parello9 Posted January 15, 2019 Share Posted January 15, 2019 Mine done this then 2 days later it broke! £500 ish to fix Quote Link to comment Share on other sites More sharing options...
neo Posted January 15, 2019 Author Share Posted January 15, 2019 which parts did you need ?? Quote Link to comment Share on other sites More sharing options...
neo Posted January 15, 2019 Author Share Posted January 15, 2019 Fuse out in 20mins, thanks for the video. Code reader ordered should be here tomorrow. 1 Quote Link to comment Share on other sites More sharing options...
neo Posted January 16, 2019 Author Share Posted January 16, 2019 Just tried the u480 reader, no fault codes Didn't look at other menus on the reader, didn't want to mess something else up, any ideas ??? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 16, 2019 Share Posted January 16, 2019 I would only be guessing mate, best to nip into Nissan and get your car hooked up to Consult . Quote Link to comment Share on other sites More sharing options...
neo Posted January 16, 2019 Author Share Posted January 16, 2019 yeah that's what i'm thinking too, might try my local garage first see if they can help, thanks again for your help Quote Link to comment Share on other sites More sharing options...
neo Posted January 16, 2019 Author Share Posted January 16, 2019 should i still leave the fuse out when i pop to the garage ? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 16, 2019 Share Posted January 16, 2019 27 minutes ago, neo said: should i still leave the fuse out when i pop to the garage ? If you are worried replace it with a blown fuse if possible Quote Link to comment Share on other sites More sharing options...
neo Posted January 20, 2019 Author Share Posted January 20, 2019 Car still working fine, booked car into my local garage on Wednesday, hopefully they can get to the bottom of the light problem Quote Link to comment Share on other sites More sharing options...
Ebized Posted January 20, 2019 Share Posted January 20, 2019 It won't be the steering lock as they have not been fitted on 370's from the 2011 model year. You can verify this as the steering wheel can be turned with the ignition off. If you local garage is stuck then this is your answer: On 16/01/2019 at 16:41, ZMANALEX said: I would only be guessing mate, best to nip into Nissan and get your car hooked up to Consult . Quote Link to comment Share on other sites More sharing options...
neo Posted January 20, 2019 Author Share Posted January 20, 2019 Thanks Colin, thats what i thought, pulled the fuse anyways, can easily put it back in Quote Link to comment Share on other sites More sharing options...
neo Posted January 23, 2019 Author Share Posted January 23, 2019 (edited) Bugger - should have listened to Alex and took it to Nissan, they couldn't find anything wrong apart from some low voltage faults that they cleared, light still on, they seem to think its the steering solenoid, yes they googled the problem lol, now booked in for 1st Feb at Nissan where i purchased it from and see what they say. Hopefully its not a £1300 fix thats been suggested else where on the net, my local garage did say to inform nissan uk about the problem if the dealership can't find the problem and they may be able to help further. Edited January 23, 2019 by neo Quote Link to comment Share on other sites More sharing options...
neo Posted February 1, 2019 Author Share Posted February 1, 2019 (edited) dropped car off this morning to nissan, they just phoned back, it is the steering lock that as caused the fault, they can clear it but comes straight back on, for the diag and a new part its around £730 any ideas how to fix it cheaper or have i gotta bite the bullet ?? Edited February 1, 2019 by neo Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 1, 2019 Share Posted February 1, 2019 Hang on...... You drove the car to the garage? If so the steering lock IF IT HAS ONE has not failed then? From all the info we have seen, and I have just trawled through umpteen posts on other 370 forums as well as all the tech stuff issued in current Nissan blurb, and I can find no reference to 2012 and onwards 370s having steering locks, so if it were me I would be seriously questioning the dealer's findings. First and foremost, clarify if your car has a steering look - get the question raised at Nissan customer services using the fault code(s) the dealer has found. Quote Link to comment Share on other sites More sharing options...
neo Posted February 1, 2019 Author Share Posted February 1, 2019 (edited) Thx colin, Anton the master technician, swears that all 370z have a steering lock, he said it could be sticking on 1 of the 2 pins that lock it, hence the fault, i did mention why there are no lights on the fobgina, said it could be part of the same fault yeah car drives perfectly every time since the light came on, not paying £679.20 to just have the light turned off, the steering lock fuse as been back in just over a week as well and still it works apart from the damn yellow light on the dash. Edited February 1, 2019 by neo Quote Link to comment Share on other sites More sharing options...
neo Posted February 1, 2019 Author Share Posted February 1, 2019 Guess i could just put some black tape over the light Quote Link to comment Share on other sites More sharing options...
Silverthorn Posted February 1, 2019 Share Posted February 1, 2019 I'd take the fuse out and keep it out personally. The last thing you want is the steering lock to completely fail as you'll be shafted with repair bills. Not worth the risk whatsoever... No help with regards to the light though I'm afraid. Quote Link to comment Share on other sites More sharing options...
neo Posted February 1, 2019 Author Share Posted February 1, 2019 (edited) just been out to the car, seems like it does have the housing for the steering lock, there are no sounds when pushing the start/stop button, there is lock illuminated, then acc then on, just tried the car 4 times and every time it started Edited February 1, 2019 by neo Quote Link to comment Share on other sites More sharing options...
