Retro LLama Posted January 12, 2019 Share Posted January 12, 2019 Hi key fob has been playing up over the passed few days. started needing multiple inputs before opening and now doesn't open or lock by fob. I've added a new battery and have tried the below. it flashes on number 3 but not 7. any ideas how i can fix this?? it sets the alarm off every time i open the door and have to scramble to start it imagine i cant get this fixed at a Nissan garage any more 1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds. 2. Then turn ignition switch to OFF position. Leave key in ignition switch. 3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice. 4. Press and HOLD the unlock button on the Plip. 5. While pressing the unlock button, press the lock button 3 times. 6. Release the unlock button. 7. The warning lights will flash once to indicate successful programming. 8. Repeat procedure 4 to 7 for up to 4 plip key’s. 9. When completed turn ignition ON, and the warning lights will flash 2 times. 10. Remove key, and check all plip key’s for operation. any advise would be much appreciated! thanks Quote Link to comment Share on other sites More sharing options...
