Idle RPM a bit high?
Kryptek49
My HR idles at around 900rpm which seems a bit higher than the 7-800 people normally get - does this mean anything?
The car is on 99k, mostly stock apart from Cobra catback exhaust, and has been UpRev remapped.
I believe that they slightly increase the idle when remapping, but only to about 800, not 900.
AC is off.
Probably should have researched this first - followed this and all sorted: https://h-dev.co.uk/350z-reset-proceedure-pedal-dance/?v=79cba1185463
I think the idle was probably high as the previous owner used to have decats fitted but they were removed before I bought it and probably never reset the throttle hence the higher idle.
