leebottrill Posted January 3, 2019 Share Posted January 3, 2019 My oil pressure has gone weird. When the car is off it’s 0. When I turn the ignition on it’s around 60 psi, and when the engine starts it’s goes right up. The oil pressure never moved when the ignition was just on before. Any ideas? Photos are of a hot car in the above order? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 3, 2019 Share Posted January 3, 2019 Sounds like an oil pressure sender failure. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted January 3, 2019 Author Share Posted January 3, 2019 If it’s a sensor then I’m less worried! Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 3, 2019 Share Posted January 3, 2019 As Alex said, sounds like the oil pressure sensor gave up, not the most difficult or expensive fix, here's the sensor: https://www.torqen.uk/nissan/350z/engine/electronics/1019-350z-nissan-oem-oil-pressure-sending-unit-sensor-switch-25070-cd00a.html Quote Link to comment Share on other sites More sharing options...
leebottrill Posted January 3, 2019 Author Share Posted January 3, 2019 9 minutes ago, Adrian@TORQEN said: As Alex said, sounds like the oil pressure sensor gave up, not the most difficult or expensive fix, here's the sensor: https://www.torqen.uk/nissan/350z/engine/electronics/1019-350z-nissan-oem-oil-pressure-sending-unit-sensor-switch-25070-cd00a.html Will this goon the HR? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 3, 2019 Share Posted January 3, 2019 Oh, if HR, might dig deeper into it, could be the gallery gaskets failing, slightly more complex job, around £800 fix... Quote Link to comment Share on other sites More sharing options...
leebottrill Posted January 3, 2019 Author Share Posted January 3, 2019 I’ve just had the gallery gaskets done. Haha Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 3, 2019 Share Posted January 3, 2019 2 minutes ago, leebottrill said: I’ve just had the gallery gaskets done. Haha In that case could be the sensor I linked up above, details here:https://nissan.7zap.com/en/er/z/z33/2+307+509/e/253/#25070 Quote Link to comment Share on other sites More sharing options...
GrahameJ Posted January 3, 2019 Share Posted January 3, 2019 Had the same symptoms although mine would eventually go up to 120 psi and stick there. I bought the following 25070CD00A Oil Pressure Sensor from eBay which cured it completely: https://www.ebay.co.uk/itm/25070CD00A-Oil-Pressure-Sensor-Sender-Switch-Fit-Nissan-Altima-Armada-Frontier/183441585101?hash=item2ab5f873cd:g:DdkAAOSw0iBboKYL:rk:1:pf:0 Note the genuine looking Nissan packaging Quote Link to comment Share on other sites More sharing options...
