strider86 Posted April 5, 2008 Share Posted April 5, 2008 Hello people, long time since i posted but im wondering if im the only one with a irritating problem!?!? When i get over 65/70 mph i get wind noise from the top of the drivers window, is this something to do with the rubber seal around the door, or something far more sinister and annoying?? the good news is that sometimes the faster you go it goes away...is that my only option? Quote Link to comment Share on other sites More sharing options...
Stew Posted April 5, 2008 Share Posted April 5, 2008 I seem to remember reading about this before. Try the search as I'm sure iit was here it was posted. Probably the rubber however possible that window motor or stop is is causing the problem. I think the window reset is here too! Worth a try. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted April 5, 2008 Share Posted April 5, 2008 Check to make sure that when you close the door the window goes up automatically by a few mm Quote Link to comment Share on other sites More sharing options...
Zedrush Posted April 5, 2008 Share Posted April 5, 2008 I use to get that to might be window nit shutting fully allignment might be off easily fixed where you been dude you going wales meet Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 5, 2008 Share Posted April 5, 2008 Check to make sure that when you close the door the window goes up automatically by a few mm +1 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 6, 2008 Share Posted April 6, 2008 there is a window reset guide in the Guides section http://www.350z-uk.com/forum/viewtopic.php?t=141 Quote Link to comment Share on other sites More sharing options...
strider86 Posted April 13, 2008 Author Share Posted April 13, 2008 cheers for all the suggestions, sorry it has taken me so long to getting round t posting a reply, not a good week at all. suprisingly for the moment the noise has stopped, so fingers crossed it stays that way Quote Link to comment Share on other sites More sharing options...
adncd Posted August 1, 2008 Share Posted August 1, 2008 Im having this problem with my passenger door, at first i thought it was because of some cracked paint above the door, but just had that fixed and the noise is still their. I did not think it was the window becuase it does go down and then back up when the door is opend and closed but when looking last night it appears to be not going all the way up. When i try to move it up the extra bit it does not budge, but the motor clicks. Having read the post this looks like it needs resetting. Can you confirm this is correct, and how much time this is likly to take, the uk weather is unpredictable and don't want to get caught short with my door in pieces. thanks Quote Link to comment Share on other sites More sharing options...
adncd Posted August 1, 2008 Share Posted August 1, 2008 OK checked window again and the window is returning to the full up position as far as i can see but it looks like the door seal might not be in properly. could really do with a second opinion. is there anyone near Basingstoke that would be willing to have a look? If it is the seal are these expensive to have replaced? thanks Quote Link to comment Share on other sites More sharing options...
