stuey Posted April 7, 2008 Share Posted April 7, 2008 are the tyres on in the correct directional rotation............ Quote Link to comment Share on other sites More sharing options...
captint Posted April 7, 2008 Share Posted April 7, 2008 Were you on a cobbled part of the Auto Bahn Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 7, 2008 Share Posted April 7, 2008 are the tyres on in the correct directional rotation............ yeah not the first time this has been done but don't think it woul;d cause such violent shaking Quote Link to comment Share on other sites More sharing options...
stuey Posted April 7, 2008 Share Posted April 7, 2008 only thing with this complaint is that tecchies or garages will not test at that speed Quote Link to comment Share on other sites More sharing options...
Emperor Ming Posted April 7, 2008 Share Posted April 7, 2008 Take it to a garage and get the drop links and wish bones checked. The bushes may LOOK fine and you will not be able to move them by hand (If you can they really are fubar'ed) but any decent mechanic will tell if they are worn, shot etc. This can and will cause the problem you describe. Check the wheels to make sure the balance weights they put on are STILL THERE. The sticky ones easily fly off and the wheels will then be miles out again!! Mrs Ming had the same problem with her Celica and it was a damaged tyre - on the back. If you do not feel it through the steering wheel it is not the front wheels. If you have the same size front and rear just swop them round and see if it feels any different. I would strongly advise AGAINST taking the vehicle out of gear at the speeds you are talking!! If you need to check it then just dip the clutch for a VERY brief period to see if things change. Good luck and let us know what sorts it out! Ming the every so slightly concerned Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 8, 2008 Author Share Posted April 8, 2008 Take it to a garage and get the drop links and wish bones checked. The bushes may LOOK fine and you will not be able to move them by hand (If you can they really are fubar'ed) but any decent mechanic will tell if they are worn, shot etc. This can and will cause the problem you describe.Check the wheels to make sure the balance weights they put on are STILL THERE. The sticky ones easily fly off and the wheels will then be miles out again!! Mrs Ming had the same problem with her Celica and it was a damaged tyre - on the back. If you do not feel it through the steering wheel it is not the front wheels. If you have the same size front and rear just swop them round and see if it feels any different. I would strongly advise AGAINST taking the vehicle out of gear at the speeds you are talking!! If you need to check it then just dip the clutch for a VERY brief period to see if things change. Good luck and let us know what sorts it out! Ming the every so slightly concerned you guys are gonna cuss me when i say this but the car is an automatic.so cant dip the clutch but i think the general advice is to take it to a garage more chedder required thanks for the reply.appreciate it. ming the mercelous Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 8, 2008 Share Posted April 8, 2008 Worn bushes will generally show themselves by clunking when the steering is turned and car is stationary, although why worn bushes would show at 110mph is beyond me and vey unlikely, more likely to show when braking or at a slower speed taking the car out of gear at speed would not create any problems whatsoever providing you're on a private road with no one up your chuff i did say earlier about the tyres, eggs, uneven tyre wear, my bro had a similar problem with toyos, which were replaced as they were a "bad" batch ?? it doesnt shake at all at lower speeds 60-70 mph ? poor balance normally reveals itself in increments Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 8, 2008 Author Share Posted April 8, 2008 Worn bushes will generally show themselves by clunking when the steering is turned and car is stationary, although why worn bushes would show at 110mph is beyond me and vey unlikely, more likely to show when braking or at a slower speed taking the car out of gear at speed would not create any problems whatsoever providing you're on a private road with no one up your chuff i did say earlier about the tyres, eggs, uneven tyre wear, my bro had a similar problem with toyos, which were replaced as they were a "bad" batch ?? it doesnt shake at all at lower speeds 60-70 mph ? poor balance normally reveals itself in increments well the car was shaking at just over 70.so i had the wheels balanced (i ust got the car, so was unaware of these issues). quite embarassing driving around in a 3.5 with Ford Ka's over taking you. anyway. got the wheels balanced and tested it out. now it starts shaking at just over 100. got the service done, and the chap said i had a nasty cut on the inside of one of my tyres. but i dont know if that might be causing the WHOLE car to shake. steering wheel and everything.. its almost like there are ridges on the road..light but noticable vibrations. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted April 8, 2008 Share Posted April 8, 2008 Worn bushes will generally show themselves by clunking when the steering is turned and car is stationary, although why worn bushes would show at 110mph is beyond me and vey unlikely, more likely to show when braking or at a slower speed taking the car out of gear at speed would not create any problems whatsoever providing you're on a private road with no one up your chuff i did say earlier about the tyres, eggs, uneven tyre wear, my bro had a similar problem with toyos, which were replaced as they were a "bad" batch ?? it doesnt shake at all at lower speeds 60-70 mph ? poor balance normally reveals itself in increments well the car was shaking at just over 70.so i had the wheels balanced (i ust got the car, so was unaware of these issues). quite embarassing driving around in a 3.5 with Ford Ka's over taking you. anyway. got the wheels balanced and tested it out. now it starts shaking at just over 100. got the service done, and the chap said i had a nasty cut on the inside of one of my tyres. but i dont know if that might be causing the WHOLE car to shake. steering wheel and everything.. its almost like there are ridges on the road..light but noticable vibrations. only other thing I can think it could be is sarnie put his dildo in your boot that turns on at over a 100 mph, have a check Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 8, 2008 Share Posted April 8, 2008 Worn bushes will generally show themselves by clunking when the steering is turned and car is stationary, although why worn bushes would show at 110mph is beyond me and vey unlikely, more likely to show when braking or at a slower speed taking the car out of gear at speed would not create any problems whatsoever providing you're on a private road with no one up your chuff i did say earlier about the tyres, eggs, uneven tyre wear, my bro had a similar problem with toyos, which were replaced as they were a "bad" batch ?? it doesnt shake at all at lower speeds 60-70 mph ? poor balance normally reveals itself in increments well the car was shaking at just over 70.so i had the wheels balanced (i ust got the car, so was unaware of these issues). quite embarassing driving around in a 3.5 with Ford Ka's over taking you. anyway. got the wheels balanced and tested it out. now it starts shaking at just over 100. got the service done, and the chap said i had a nasty cut on the inside of one of my tyres. but i dont know if that might be causing the WHOLE car to shake. steering wheel and everything.. its almost like there are ridges on the road..light but noticable vibrations. only other thing I can think it could be is sarnie put his dildo in your boot that turns on at over a 100 mph, have a check i think we have a winner Quote Link to comment Share on other sites More sharing options...
Emperor Ming Posted April 8, 2008 Share Posted April 8, 2008 The reason I said I was cautious about 'knocking it out of gear' at the speeds mentioned is that the gearing and drive of a car gives an element of control to the car. If it is shaking and you knock it out of gear the problem COULD get worse. With no gearbox to drive through or out of the problem it COULD be dangerous. Until we knew it was automatic dipping the clutch for a few seconds seemed a much safer idea. I agree with you thoughts on the wishbone with one rider. I had a very similar problem albeit at a lower speed with a proton I had. It would come up at certain points of acceleration but got worse under breaking Previously it was described as having a small split but if the guy who balanced your tyres said its got a 'NASTY SPLIT' in one of the tyres then it has hit either a rock or a kerb and as such the tyre/wheel is almost certainly the problem. Let us know the outcome. Ming the interested Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 8, 2008 Share Posted April 8, 2008 the ideal would be to swop the wheels - front to back if poss, this would indentify if the tyre/wheel is the problem and which it is Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 8, 2008 Author Share Posted April 8, 2008 The reason I said I was cautious about 'knocking it out of gear' at the speeds mentioned is that the gearing and drive of a car gives an element of control to the car. If it is shaking and you knock it out of gear the problem COULD get worse. With no gearbox to drive through or out of the problem it COULD be dangerous. Until we knew it was automatic dipping the clutch for a few seconds seemed a much safer idea.I agree with you thoughts on the wishbone with one rider. I had a very similar problem albeit at a lower speed with a proton I had. It would come up at certain points of acceleration but got worse under breaking Previously it was described as having a small split but if the guy who balanced your tyres said its got a 'NASTY SPLIT' in one of the tyres then it has hit either a rock or a kerb and as such the tyre/wheel is almost certainly the problem. Let us know the outcome. Ming the interested the nasty cut is in the front passenger side tyre, which i need to replace anyway. but i would have thought the shake would have been limited to the steering at taht speed.not the whole car i think im gonna have to get it checked out somehow and change the tyres anyway the ideal would be to swop the wheels - front to back if poss, this would indentify if the tyre/wheel is the problem and which it is back and front wheels are not the same width to swap im afraid Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 9, 2008 Share Posted April 9, 2008 I think that is why GIXXERUK said in an ideal world Quote Link to comment Share on other sites More sharing options...
Emperor Ming Posted April 10, 2008 Share Posted April 10, 2008 Do you know another Zed owner nearby? If so swop all wheels from one car to the other and try it. It will take more time to swop the wheels that it will to test it but at least you will KNOW whether the wheel tyre combination is to blame. Ming the considered PS Nasty cut in front tyre + brick or other object in road = blown tyre and CRASH Take it steady dude. Ming the Worried Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 11, 2008 Author Share Posted April 11, 2008 Do you know another Zed owner nearby?If so swop all wheels from one car to the other and try it. It will take more time to swop the wheels that it will to test it but at least you will KNOW whether the wheel tyre combination is to blame. Ming the considered PS Nasty cut in front tyre + brick or other object in road = blown tyre and CRASH Take it steady dude. Ming the Worried oh lord ming thank you for that suggestion. unfortunately i live in a crap area and dont know any body there!! the only one i know who has a z is in florida iv been given so many suggestions here im scared shitless. bushings tyres wheel nuts wish bone spacers lol. wtf did i end up buying!! i do need to get front tyres replaced cos of the cut.. decent ones are 100 a pop.low on cash right now..so risking my life for 200 smackers anyone know where to get some decent lock in wheel nuts? no one seems to blooming stock em! its unbelievable? also tyres..any good places? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted April 11, 2008 Share Posted April 11, 2008 Do you know another Zed owner nearby?If so swop all wheels from one car to the other and try it. It will take more time to swop the wheels that it will to test it but at least you will KNOW whether the wheel tyre combination is to blame. Ming the considered PS Nasty cut in front tyre + brick or other object in road = blown tyre and CRASH Take it steady dude. Ming the Worried oh lord ming thank you for that suggestion. unfortunately i live in a crap area and dont know any body there!! the only one i know who has a z is in florida iv been given so many suggestions here im scared shitless. bushings tyres wheel nuts wish bone spacers lol. wtf did i end up buying!! i do need to get front tyres replaced cos of the cut.. decent ones are 100 a pop.low on cash right now..so risking my life for 200 smackers anyone know where to get some decent lock in wheel nuts? no one seems to blooming stock em! its unbelievable? also tyres..any good places? where about you based mate, if you are near my neck of the woods ill come see ya and will bring spare wheel for you to try Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 11, 2008 Author Share Posted April 11, 2008 Do you know another Zed owner nearby?If so swop all wheels from one car to the other and try it. It will take more time to swop the wheels that it will to test it but at least you will KNOW whether the wheel tyre combination is to blame. Ming the considered PS Nasty cut in front tyre + brick or other object in road = blown tyre and CRASH Take it steady dude. Ming the Worried oh lord ming thank you for that suggestion. unfortunately i live in a crap area and dont know any body there!! the only one i know who has a z is in florida iv been given so many suggestions here im scared shitless. bushings tyres wheel nuts wish bone spacers lol. wtf did i end up buying!! i do need to get front tyres replaced cos of the cut.. decent ones are 100 a pop.low on cash right now..so risking my life for 200 smackers anyone know where to get some decent lock in wheel nuts? no one seems to blooming stock em! its unbelievable? also tyres..any good places? where about you based mate, if you are near my neck of the woods ill come see ya and will bring spare wheel for you to try zrush, ur a star for offering. and i would take u up on it if it wasnt for me feeling utterly guilty afterwards. i live in colchester. where abouts are you? i could come to u Quote Link to comment Share on other sites More sharing options...
Zedrush Posted April 12, 2008 Share Posted April 12, 2008 is that colchester essex? Im just on the otherside of the dartford tunnel Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 12, 2008 Author Share Posted April 12, 2008 is that colchester essex? Im just on the otherside of the dartford tunnel yes essex between chelsmford and ipswich..toward norwich ur in kent then? Quote Link to comment Share on other sites More sharing options...
Zedrush Posted April 13, 2008 Share Posted April 13, 2008 is that colchester essex? Im just on the otherside of the dartford tunnel yes essex between chelsmford and ipswich..toward norwich ur in kent then? well London kinda, near greenwich and blackheath but takes me 10 mins to get to bluewater Quote Link to comment Share on other sites More sharing options...
Newbie 350GT Posted April 13, 2008 Author Share Posted April 13, 2008 is that colchester essex? Im just on the otherside of the dartford tunnel yes essex between chelsmford and ipswich..toward norwich ur in kent then? well London kinda, near greenwich and blackheath but takes me 10 mins to get to bluewater cool brother man ill email you the update. gonna get the tyres changed anyway cos of the cut on it.. if that fails.ill defo take u up on that offer. thanks man..appreciate it. Quote Link to comment Share on other sites More sharing options...
Zedrush Posted April 13, 2008 Share Posted April 13, 2008 is that colchester essex? Im just on the otherside of the dartford tunnel yes essex between chelsmford and ipswich..toward norwich ur in kent then? well London kinda, near greenwich and blackheath but takes me 10 mins to get to bluewater cool brother man ill email you the update. gonna get the tyres changed anyway cos of the cut on it.. if that fails.ill defo take u up on that offer. thanks man..appreciate it. no worries Quote Link to comment Share on other sites More sharing options...
