chefey Posted December 17, 2018 Share Posted December 17, 2018 Sometimes when closing doors one of the windows lowers halfway, can be either window, does not do it every time, nothing is caught in window. Is it some kind f safety thing or do I have a fault and is it an easy fix. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted December 17, 2018 Share Posted December 17, 2018 I would start by re-setting the windows Quote Link to comment Share on other sites More sharing options...
chefey Posted December 17, 2018 Author Share Posted December 17, 2018 Thanks ATTAK .... I have a manual I downloaded, I believe it tells you how to do it. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted December 17, 2018 Share Posted December 17, 2018 look here 1 Quote Link to comment Share on other sites More sharing options...
chefey Posted December 17, 2018 Author Share Posted December 17, 2018 ATTAK.... You are a star, battery was off car earlier in the year, so that is probably what caused problem. It would only do it every couple of weeks, but sure that was what caused problem. Will go and reset them later. The manual I downloaded is not the easiest to use, would have been on an eternity to find that, I wonder if it would even have had that reset cure. Thanks very much, you are a true gent. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted December 17, 2018 Share Posted December 17, 2018 Quote Link to comment Share on other sites More sharing options...
