Need to drill this...
RobPhoboS
Just now, rabbitstew said:
Should be able to use a normal centre punch and punch a small dent in it, then drill through it with a suitable sized drill bit. Might be hard to clamp it in a vice though without it getting squished!
I'll go an grab a normal centre punch today, hopefully it'll work.
I've got a weighty mallet to whack it with :lol:
If the vice can't hold it properly, I thought perhaps my locking pliers might do the trick on the floor (with some wood underneath so the drill bit doesn't hit the floor).
Thank you :)
Drilling will also be a major problem for you as standard HSS drill bits will not look at these buckets.
You will require Cobalt (HSCO) or Carbide (CARB)
Might be a plan to send this small drilling job to your local engineering firm.
I appreciate the advice !
I bought quite a heavy duty centre punch (8mm 120g), I'm hopeful it'll do the trick.
If not, I've asked the guy that did my seat as he has a pillar drill. Unfortunately he's always busy AF, so I'm not sure he'll get the time to do it (as I need it by next week ideally).
And of course this time of year is quite difficult.
Edited by RobPhoboS
6 minutes ago, Mark@Abbey m/s said:
I doubt your mark it with a centre punch, maybe using a grinder (stone tipped) and work through the hardness then you maybe able to drill it, but it is hardened on the under-side as well.
Why are you trying to drill a hole through a 350Z tappet bucket?
Hey Mark, long time no see !
It's to use with the JWT tool, I have one pre-drilled but the other 3 that the seller included aren't (it's a pity to do it!).
Granted, it's not like I'll be in a rush but will save a bit of messing around.
JWTVQValveSpringCompressor-696313c7.jpg&
3 minutes ago, Mark@Abbey m/s said:
oil usages issues.  I would put a fiver on it being piston  rings not valve stem seals
Probably a combination but doing this part anyway, too late now :lol:
I have a separate thread for it, so will of course show my findings (doing timing chain and other bits and pieces).
