Rackers Posted December 7, 2018 Share Posted December 7, 2018 Passenger side window is leaking around where the tweeter is. Is it likely to be the weather seal between the mirror and sail panel? Or do these leaks usually start elsewhere? Quote Link to comment Share on other sites More sharing options...
Jack94 Posted December 7, 2018 Share Posted December 7, 2018 Most likely to be the weatherstrip that runs along the top of the door shut. First thing is do is whip the doorcard off and adjust the angle of the window slightly so it pushes against the seal a bit more. Quote Link to comment Share on other sites More sharing options...
Rackers Posted December 7, 2018 Author Share Posted December 7, 2018 Thanks will give this a go! Quote Link to comment Share on other sites More sharing options...
