Headlight washer issue.... HELP!
calumrobertmacdonald
Hi folks, wondering if you can help.....
my headlight washers are activating on their own accord (both when the engine is on or off) and I believe there must be some issue with the electrics as they go off then come back on  ~30 secs to a minute later..... the button next to the esp off doesn’t seem to do anything!?
has as anyone experienced this before or have suggestions to resolve this!
Many thanks in advance for any help!
cheers
Calum
  • 3 weeks later...
Just in case anyone else experiences the same issue I initially pulled out the headlight washer relay which is located below the trim next to the fuse box which thankfully stopped the pump. I bought a new relay, fitted it and it appears to have sorted the issue! £5 fix i'll take that any day!
Cheers.
